REST API reference
Retrieve an FPolicy configuration
Accesses and views an FPolicy configuration to understand its settings and parameters within your system. This can be useful for auditing, troubleshooting, or configuring file access policies.
HTTP method and endpoint
GET /protocols/fpolicy
Introduced in
ONTAP 9.6
Usage notes
Retrieves an FPolicy configuration.
  • fpolicy show
  • fpolicy policy show
  • fpolicy policy scope show
  • fpolicy policy event show
  • fpolicy policy external-engine show
engines.secondary_servers
string
query
False
Filter by engines.secondary_servers
engines.name
string
query
False
Filter by engines.name
engines.port
integer
query
False
Filter by engines.port
engines.primary_servers
string
query
False
Filter by engines.primary_servers
engines.type
string
query
False
Filter by engines.type
policies.events.name
string
query
False
Filter by policies.events.name
policies.name
string
query
False
Filter by policies.name
policies.engine.name
string
query
False
Filter by policies.engine.name
policies.scope.include_shares
string
query
False
Filter by policies.scope.include_shares
policies.scope.exclude_extension
string
query
False
Filter by policies.scope.exclude_extension
policies.scope.exclude_shares
string
query
False
Filter by policies.scope.exclude_shares
policies.scope.exclude_volumes
string
query
False
Filter by policies.scope.exclude_volumes
policies.scope.exclude_export_policies
string
query
False
Filter by policies.scope.exclude_export_policies
policies.scope.include_extension
string
query
False
Filter by policies.scope.include_extension
policies.scope.include_volumes
string
query
False
Filter by policies.scope.include_volumes
policies.scope.include_export_policies
string
query
False
Filter by policies.scope.include_export_policies
policies.mandatory
boolean
query
False
Filter by policies.mandatory
policies.enabled
boolean
query
False
Filter by policies.enabled
policies.priority
integer
query
False
Filter by policies.priority
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
events.volume_monitoring
boolean
query
False
Filter by events.volume_monitoring
events.protocol
string
query
False
Filter by events.protocol
events.name
string
query
False
Filter by events.name
events.filters.setattr_with_group_change
boolean
query
False
Filter by events.filters.setattr_with_group_change
events.filters.setattr_with_size_change
boolean
query
False
Filter by events.filters.setattr_with_size_change
events.filters.first_read
boolean
query
False
Filter by events.filters.first_read
events.filters.close_with_read
boolean
query
False
Filter by events.filters.close_with_read
events.filters.setattr_with_owner_change
boolean
query
False
Filter by events.filters.setattr_with_owner_change
events.filters.open_with_write_intent
boolean
query
False
Filter by events.filters.open_with_write_intent
events.filters.setattr_with_modify_time_change
boolean
query
False
Filter by events.filters.setattr_with_modify_time_change
events.filters.setattr_with_allocation_size_change
boolean
query
False
Filter by events.filters.setattr_with_allocation_size_change
events.filters.write_with_size_change
boolean
query
False
Filter by events.filters.write_with_size_change
events.filters.close_without_modification
boolean
query
False
Filter by events.filters.close_without_modification
events.filters.setattr_with_mode_change
boolean
query
False
Filter by events.filters.setattr_with_mode_change
events.filters.close_with_modification
boolean
query
False
Filter by events.filters.close_with_modification
events.filters.exclude_directory
boolean
query
False
Filter by events.filters.exclude_directory
events.filters.offline_bit
boolean
query
False
Filter by events.filters.offline_bit
events.filters.setattr_with_dacl_change
boolean
query
False
Filter by events.filters.setattr_with_dacl_change
events.filters.setattr_with_access_time_change
boolean
query
False
Filter by events.filters.setattr_with_access_time_change
events.filters.setattr_with_sacl_change
boolean
query
False
Filter by events.filters.setattr_with_sacl_change
events.filters.open_with_delete_intent
boolean
query
False
Filter by events.filters.open_with_delete_intent
events.filters.monitor_ads
boolean
query
False
Filter by events.filters.monitor_ads
events.filters.first_write
boolean
query
False
Filter by events.filters.first_write
events.filters.setattr_with_creation_time_change
boolean
query
False
Filter by events.filters.setattr_with_creation_time_change
events.file_operations.link
boolean
query
False
Filter by events.file_operations.link
events.file_operations.write
boolean
query
False
Filter by events.file_operations.write
events.file_operations.rename
boolean
query
False
Filter by events.file_operations.rename
events.file_operations.delete_dir
boolean
query
False
Filter by events.file_operations.delete_dir
boolean
query
False
events.file_operations.setattr
boolean
query
False
Filter by events.file_operations.setattr
events.file_operations.close
boolean
query
False
Filter by events.file_operations.close
events.file_operations.open
boolean
query
False
Filter by events.file_operations.open
events.file_operations.create_dir
boolean
query
False
Filter by events.file_operations.create_dir
events.file_operations.rename_dir
boolean
query
False
Filter by events.file_operations.rename_dir
boolean
query
False
events.file_operations.read
boolean
query
False
Filter by events.file_operations.read
events.file_operations.getattr
boolean
query
False
Filter by events.file_operations.getattr
events.file_operations.lookup
boolean
query
False
Filter by events.file_operations.lookup
events.file_operations.symlink
boolean
query
False
Filter by events.file_operations.symlink
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[fpolicy]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "engines": [
          "name": "fp_ex_eng",
          "port": 9876,
          "primary_servers": [
            "10.132.145.20",
            "10.140.101.109"
          "secondary_servers": [
            "10.132.145.20",
            "10.132.145.21"
          "type": "string"
      "events": [
          "name": "event_nfs_close",
          "protocol": "string"
      "policies": [
          "engine": {
            "name": "string"
          "events": [
            "event_nfs_close",
            "event_open"
          "name": "fp_policy_1",
          "scope": {
            "exclude_export_policies": [
              "string"
            "exclude_extension": [
              "string"
            "exclude_shares": [
              "string"
            "exclude_volumes": [
              "vol1",
              "vol_svm1",
            "include_export_policies": [
              "string"
            "include_extension": [
              "string"
            "include_shares": [
              "sh1",
              "share_cifs"
            "include_volumes": [
              "vol1",
              "vol_svm1"
      "svm": {
        "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
fpolicy_engines
The engine defines how ONTAP makes and manages connections to external FPolicy servers.
name
string
Specifies the name to assign to the external server configuration.
port
integer
Port number of the FPolicy server application.
primary_servers
array[string]
secondary_servers
array[string]
type
string
The notification mode determines what ONTAP does after sending notifications to FPolicy servers. The possible values are:
  • synchronous - After sending a notification, wait for a response from the FPolicy server.
  • asynchronous - After sending a notification, file request processing continues.
    • Default value: 1
    • enum: ["synchronous", "asynchronous"]
    • Introduced in: 9.10
file_operations
Specifies the file operations for the FPolicy event. You must specify a valid protocol in the protocol parameter. The event will check the operations specified from all client requests using the protocol.
close
boolean
File close operations
create
boolean
File create operations
create_dir
boolean
Directory create operations
delete
boolean
File delete operations
delete_dir
boolean
Directory delete operations
getattr
boolean
Get attribute operations
link
boolean
Link operations
lookup
boolean
Lookup operations
open
boolean
File open operations
read
boolean
File read operations
rename
boolean
File rename operations
rename_dir
boolean
Directory rename operations
setattr
boolean
Set attribute operations
symlink
boolean
Symbolic link operations
write
boolean
File write operations
filters
Specifies the list of filters for a given file operation for the specified protocol. When you specify the filters, you must specify the valid protocols and a valid file operations.
boolean
Filter the client request for close with modification.
close_with_read
boolean
Filter the client request for close with read.
boolean
Filter the client request for close without modification.
exclude_directory
boolean
Filter the client requests for directory operations. When this filter is specified directory operations are not monitored.
first_read
boolean
Filter the client requests for the first-read.
first_write
boolean
Filter the client requests for the first-write.
monitor_ads
boolean
Filter the client request for alternate data stream.
offline_bit
boolean
Filter the client request for offline bit set. FPolicy server receives notification only when offline files are accessed.
boolean
Filter the client request for open with delete intent.
boolean
Filter the client request for open with write intent.
boolean
Filter the client setattr requests for changing the access time of a file or directory.
boolean
Filter the client setattr requests for changing the allocation size of a file.
boolean
Filter the client setattr requests for changing the creation time of a file or directory.
boolean
Filter the client setattr requests for changing dacl on a file or directory.
boolean
Filter the client setattr requests for changing group of a file or directory.
boolean
Filter the client setattr requests for changing the mode bits on a file or directory.
boolean
Filter the client setattr requests for changing the modification time of a file or directory.
boolean
Filter the client setattr requests for changing owner of a file or directory.
boolean
Filter the client setattr requests for changing sacl on a file or directory.
boolean
Filter the client setattr requests for changing the size of a file.
boolean
Filter the client request for write with size change.
fpolicy_events
The information that a FPolicy process needs to determine what file access operations to monitor and for which of the monitored events notifications should be sent to the external FPolicy server.
file_operations
file_operations
filters
filters
name
string
Specifies the name of the FPolicy event.
protocol
string
Protocol for which event is created. If you specify protocol, then you must also specify a valid value for the file operation parameters. The value of this parameter must be one of the following:
  • cifs - for the CIFS protocol.
  • nfsv3 - for the NFSv3 protocol.
  • nfsv4 - for the NFSv4 protocol.
volume_monitoring
boolean
Specifies whether volume operation monitoring is required.
fpolicy_engine_reference
FPolicy external engine
_links
_links
name
string
The name of the FPolicy external engine.
fpolicy_event_reference
FPolicy events
_links
_links
name
string
scope
array[string]
exclude_extension
array[string]
exclude_shares
array[string]
exclude_volumes
array[string]
array[string]
include_extension
array[string]
include_shares
array[string]
include_volumes
array[string]
fpolicy_policies
enabled
boolean
Specifies if the policy is enabled on the SVM or not. If no value is mentioned for this field but priority is set, then this policy will be enabled.
engine
events
array[fpolicy_event_reference]
mandatory
boolean
Specifies what action to take on a file access event in a case when all primary and secondary servers are down or no response is received from the FPolicy servers within a given timeout period. When this parameter is set to true, file access events will be denied under these circumstances.
name
string
Specifies the name of the policy.
priority
integer
Specifies the priority that is assigned to this policy.
scope
scope
svm
_links
_links
name
string
The name of the SVM.
uuid
string
fpolicy
FPolicy is an infrastructure component of ONTAP that enables partner applications connected to your storage systems to monitor and set file access permissions. Every time a client accesses a file from a storage system, based on the configuration of FPolicy, the partner application is notified about file access.
_links
_links
engines
array[fpolicy_engines]
events
array[fpolicy_events]
policies
array[fpolicy_policies]
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
