REST API reference
Retrieve an FPolicy configuration
Retrieves an FPolicy configuration to review or manage the policies that govern file access and operations on your storage system.
HTTP method and endpoint
GET /protocols/fpolicy
Introduced in
ONTAP 9.6
  • fpolicy show
  • fpolicy policy show
  • fpolicy policy scope show
  • fpolicy policy event show
  • fpolicy policy external-engine show
events.file_operations.write
boolean
query
False
Filter by events.file_operations.write
events.file_operations.access
boolean
query
False
Filter by events.file_operations.access
  • Introduced in: 9.13
events.file_operations.rename
boolean
query
False
Filter by events.file_operations.rename
events.file_operations.create
boolean
query
False
Filter by events.file_operations.create
events.file_operations.delete
boolean
query
False
Filter by events.file_operations.delete
events.file_operations.symlink
boolean
query
False
Filter by events.file_operations.symlink
events.file_operations.lookup
boolean
query
False
Filter by events.file_operations.lookup
events.file_operations.rename_dir
boolean
query
False
Filter by events.file_operations.rename_dir
events.file_operations.open
boolean
query
False
Filter by events.file_operations.open
events.file_operations.create_dir
boolean
query
False
Filter by events.file_operations.create_dir
events.file_operations.link
boolean
query
False
Filter by events.file_operations.link
events.file_operations.setattr
boolean
query
False
Filter by events.file_operations.setattr
events.file_operations.read
boolean
query
False
Filter by events.file_operations.read
events.file_operations.delete_dir
boolean
query
False
Filter by events.file_operations.delete_dir
events.file_operations.close
boolean
query
False
Filter by events.file_operations.close
events.file_operations.getattr
boolean
query
False
Filter by events.file_operations.getattr
events.name
string
query
False
Filter by events.name
events.filters.write_with_size_change
boolean
query
False
Filter by events.filters.write_with_size_change
events.filters.setattr_with_modify_time_change
boolean
query
False
Filter by events.filters.setattr_with_modify_time_change
events.filters.setattr_with_dacl_change
boolean
query
False
Filter by events.filters.setattr_with_dacl_change
events.filters.first_write
boolean
query
False
Filter by events.filters.first_write
events.filters.setattr_with_group_change
boolean
query
False
Filter by events.filters.setattr_with_group_change
events.filters.open_with_delete_intent
boolean
query
False
Filter by events.filters.open_with_delete_intent
events.filters.setattr_with_size_change
boolean
query
False
Filter by events.filters.setattr_with_size_change
events.filters.setattr_with_allocation_size_change
boolean
query
False
Filter by events.filters.setattr_with_allocation_size_change
events.filters.monitor_ads
boolean
query
False
Filter by events.filters.monitor_ads
events.filters.setattr_with_owner_change
boolean
query
False
Filter by events.filters.setattr_with_owner_change
events.filters.close_without_modification
boolean
query
False
Filter by events.filters.close_without_modification
events.filters.close_with_read
boolean
query
False
Filter by events.filters.close_with_read
events.filters.setattr_with_sacl_change
boolean
query
False
Filter by events.filters.setattr_with_sacl_change
events.filters.setattr_with_access_time_change
boolean
query
False
Filter by events.filters.setattr_with_access_time_change
events.filters.close_with_modification
boolean
query
False
Filter by events.filters.close_with_modification
events.filters.offline_bit
boolean
query
False
Filter by events.filters.offline_bit
events.filters.exclude_directory
boolean
query
False
Filter by events.filters.exclude_directory
events.filters.first_read
boolean
query
False
Filter by events.filters.first_read
events.filters.setattr_with_mode_change
boolean
query
False
Filter by events.filters.setattr_with_mode_change
events.filters.setattr_with_creation_time_change
boolean
query
False
Filter by events.filters.setattr_with_creation_time_change
events.filters.open_with_write_intent
boolean
query
False
Filter by events.filters.open_with_write_intent
events.volume_monitoring
boolean
query
False
Filter by events.volume_monitoring
events.monitor_fileop_failure
boolean
query
False
Filter by events.monitor_fileop_failure
events.protocol
string
query
False
Filter by events.protocol
engines.type
string
query
False
Filter by engines.type
engines.buffer_size.recv_buffer
integer
query
False
Filter by engines.buffer_size.recv_buffer
  • Introduced in: 9.11
  • Max value: 7895160
  • Min value: 0
engines.buffer_size.send_buffer
integer
query
False
Filter by engines.buffer_size.send_buffer
  • Min value: 0
engines.request_cancel_timeout
string
query
False
Filter by engines.request_cancel_timeout
engines.format
string
query
False
Filter by engines.format
engines.primary_servers
string
query
False
Filter by engines.primary_servers
engines.port
integer
query
False
Filter by engines.port
engines.secondary_servers
string
query
False
Filter by engines.secondary_servers
engines.name
string
query
False
Filter by engines.name
engines.max_server_requests
integer
query
False
Filter by engines.max_server_requests
  • Max value: 10000
  • Min value: 1
engines.status_request_interval
string
query
False
Filter by engines.status_request_interval
engines.keep_alive_interval
string
query
False
Filter by engines.keep_alive_interval
engines.ssl_option
string
query
False
Filter by engines.ssl_option
engines.server_progress_timeout
string
query
False
Filter by engines.server_progress_timeout
engines.resiliency.directory_path
string
query
False
Filter by engines.resiliency.directory_path
engines.resiliency.retention_duration
string
query
False
Filter by engines.resiliency.retention_duration
engines.resiliency.enabled
boolean
query
False
Filter by engines.resiliency.enabled
engines.certificate.serial_number
string
query
False
Filter by engines.certificate.serial_number
engines.certificate.ca
string
query
False
Filter by engines.certificate.ca
engines.certificate.name
string
query
False
Filter by engines.certificate.name
engines.request_abort_timeout
string
query
False
Filter by engines.request_abort_timeout
policies.engine.name
string
query
False
Filter by policies.engine.name
policies.privileged_user
string
query
False
Filter by policies.privileged_user
policies.enabled
boolean
query
False
Filter by policies.enabled
policies.passthrough_read
boolean
query
False
Filter by policies.passthrough_read
policies.mandatory
boolean
query
False
Filter by policies.mandatory
policies.name
string
query
False
Filter by policies.name
policies.priority
integer
query
False
Filter by policies.priority
  • Max value: 10
  • Min value: 1
policies.allow_privileged_access
boolean
query
False
Filter by policies.allow_privileged_access
policies.scope.exclude_export_policies
string
query
False
Filter by policies.scope.exclude_export_policies
policies.scope.include_volumes
string
query
False
Filter by policies.scope.include_volumes
policies.scope.check_extensions_on_directories
boolean
query
False
Filter by policies.scope.check_extensions_on_directories
policies.scope.include_export_policies
string
query
False
Filter by policies.scope.include_export_policies
policies.scope.object_monitoring_with_no_extension
boolean
query
False
Filter by policies.scope.object_monitoring_with_no_extension
policies.scope.exclude_shares
string
query
False
Filter by policies.scope.exclude_shares
policies.scope.exclude_volumes
string
query
False
Filter by policies.scope.exclude_volumes
policies.scope.include_shares
string
query
False
Filter by policies.scope.include_shares
policies.scope.exclude_extension
string
query
False
Filter by policies.scope.exclude_extension
policies.scope.include_extension
string
query
False
Filter by policies.scope.include_extension
policies.events.name
string
query
False
Filter by policies.events.name
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[fpolicy]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "engines": [
          "certificate": {
            "ca": "TASample1",
            "name": "Sample1-FPolicy-Client",
            "serial_number": "8DDE112A114D1FBC"
          "format": "string",
          "keep_alive_interval": "PT2M",
          "max_server_requests": 500,
          "name": "fp_ex_eng",
          "port": 9876,
          "primary_servers": [
            "10.132.145.20",
            "10.140.101.109"
          "request_abort_timeout": "PT40S",
          "request_cancel_timeout": "PT20S",
          "resiliency": {
            "directory_path": "/dir1",
            "retention_duration": "PT3M"
          "secondary_servers": [
            "10.132.145.20",
            "10.132.145.21"
          "server_progress_timeout": "PT1M",
          "ssl_option": "string",
          "status_request_interval": "PT10S",
          "type": "string"
      "events": [
          "name": "event_nfs_close",
          "protocol": "string"
      "policies": [
          "engine": {
            "name": "string"
          "events": [
            "event_nfs_close",
            "event_open"
          "name": "fp_policy_1",
          "privileged_user": "mydomain\\testuser",
          "scope": {
            "exclude_export_policies": [
              "string"
            "exclude_extension": [
              "string"
            "exclude_shares": [
              "string"
            "exclude_volumes": [
              "vol1",
              "vol_svm1",
            "include_export_policies": [
              "string"
            "include_extension": [
              "string"
            "include_shares": [
              "sh1",
              "share_cifs"
            "include_volumes": [
              "vol1",
              "vol_svm1"
      "svm": {
        "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
buffer_size
Specifies the send and receive buffer size of the connected socket for the FPolicy server.
recv_buffer
integer
Specifies the receive buffer size of the connected socket for the FPolicy server. Default value is 256KB.
send_buffer
integer
Specifies the send buffer size of the connected socket for the FPolicy server. Default value 1MB.
certificate
Provides details about certificate used to authenticate the Fpolicy server.
ca
string
Specifies the certificate authority (CA) name of the certificate used for authentication if SSL authentication between the SVM and the FPolicy server is configured.
name
string
Specifies the certificate name as a fully qualified domain name (FQDN) or custom common name. The certificate is used if SSL authentication between the SVM and the FPolicy server is configured.
serial_number
string
Specifies the serial number of the certificate used for authentication if SSL authentication between the SVM and the FPolicy server is configured.
resiliency
If all primary and secondary servers are down, or if no response is received from the FPolicy servers, file access events are stored inside the storage controller under the specified resiliency-directory-path.
directory_path
string
Specifies the directory path under the SVM namespace, where notifications are stored in the files whenever a network outage happens.
enabled
boolean
Specifies whether the resiliency feature is enabled or not. Default is false.
retention_duration
string
Specifies the ISO-8601 duration, for which the notifications are written to files inside the storage controller during a network outage. The value for this field must be between 0 and 600 seconds. Default is 180 seconds.
fpolicy_engines
Defines how ONTAP makes and manages connections to external FPolicy servers.
buffer_size
buffer_size
certificate
certificate
format
string
The format for the notification messages sent to the FPolicy servers. The possible values are:
  • xml - Notifications sent to the FPolicy server will be formatted using the XML schema.
  • protobuf - Notifications sent to the FPolicy server will be formatted using Protobuf schema, which is a binary form.
keep_alive_interval
string
Specifies the ISO-8601 interval time for a storage appliance to send Keep Alive message to an FPolicy server. The allowed range is between 10 to 600 seconds.
max_server_requests
integer
Specifies the maximum number of outstanding requests for the FPolicy server. It is used to specify maximum outstanding requests that will be queued up for the FPolicy server. The value for this field must be between 1 and 10000. The default values are 500, 1000 or 2000 for Low-end(<64 GB memory), Mid-end(>=64 GB memory) and High-end(>=128 GB memory) Platforms respectively.
name
string
Specifies the name to assign to the external server configuration.
port
integer
Port number of the FPolicy server application.
primary_servers
array[string]
string
Specifies the ISO-8601 timeout duration for a screen request to be aborted by a storage appliance. The allowed range is between 0 to 200 seconds.
string
Specifies the ISO-8601 timeout duration for a screen request to be processed by an FPolicy server. The allowed range is between 0 to 100 seconds.
resiliency
resiliency
secondary_servers
array[string]
string
Specifies the ISO-8601 timeout duration in which a throttled FPolicy server must complete at least one screen request. If no request is processed within the timeout, connection to the FPolicy server is terminated. The allowed range is between 0 to 100 seconds.
ssl_option
string
Specifies the SSL option for external communication with the FPolicy server. Possible values include the following:
  • no_auth When set to "no_auth", no authentication takes place.
  • server_auth When set to "server_auth", only the FPolicy server is authenticated by the SVM. With this option, before creating the FPolicy external engine, the administrator must install the public certificate of the certificate authority (CA) that signed the FPolicy server certificate.
  • mutual_auth When set to "mutual_auth", mutual authentication takes place between the SVM and the FPolicy server. This means authentication of the FPolicy server by the SVM along with authentication of the SVM by the FPolicy server. With this option, before creating the FPolicy external engine, the administrator must install the public certificate of the certificate authority (CA) that signed the FPolicy server certificate along with the public certificate and key file for authentication of the SVM.
string
Specifies the ISO-8601 interval time for a storage appliance to query a status request from an FPolicy server. The allowed range is between 0 to 50 seconds.
type
string
The notification mode determines what ONTAP does after sending notifications to FPolicy servers. The possible values are:
  • synchronous - After sending a notification, wait for a response from the FPolicy server.
  • asynchronous - After sending a notification, file request processing continues.
    • Default value: 1
    • enum: ["synchronous", "asynchronous"]
    • Introduced in: 9.10
    • x-nullable: true
file_operations
Specifies the file operations for the FPolicy event. You must specify a valid protocol in the protocol parameter. The event will check the operations specified from all client requests using the protocol.
access
boolean
Access operations
close
boolean
File close operations
create
boolean
File create operations
create_dir
boolean
Directory create operations
delete
boolean
File delete operations
delete_dir
boolean
Directory delete operations
getattr
boolean
Get attribute operations
link
boolean
Link operations
lookup
boolean
Lookup operations
open
boolean
File open operations
read
boolean
File read operations
rename
boolean
File rename operations
rename_dir
boolean
Directory rename operations
setattr
boolean
Set attribute operations
symlink
boolean
Symbolic link operations
write
boolean
File write operations
filters
Specifies the list of filters for a given file operation for the specified protocol. When you specify the filters, you must specify the valid protocols and a valid file operations.
boolean
Filter the client request for close with modification.
close_with_read
boolean
Filter the client request for close with read.
boolean
Filter the client request for close without modification.
exclude_directory
boolean
Filter the client requests for directory operations. When this filter is specified directory operations are not monitored.
first_read
boolean
Filter the client requests for the first-read.
first_write
boolean
Filter the client requests for the first-write.
monitor_ads
boolean
Filter the client request for alternate data stream.
offline_bit
boolean
Filter the client request for offline bit set. FPolicy server receives notification only when offline files are accessed.
boolean
Filter the client request for open with delete intent.
boolean
Filter the client request for open with write intent.
boolean
Filter the client setattr requests for changing the access time of a file or directory.
boolean
Filter the client setattr requests for changing the allocation size of a file.
boolean
Filter the client setattr requests for changing the creation time of a file or directory.
boolean
Filter the client setattr requests for changing dacl on a file or directory.
boolean
Filter the client setattr requests for changing group of a file or directory.
boolean
Filter the client setattr requests for changing the mode bits on a file or directory.
boolean
Filter the client setattr requests for changing the modification time of a file or directory.
boolean
Filter the client setattr requests for changing owner of a file or directory.
boolean
Filter the client setattr requests for changing sacl on a file or directory.
boolean
Filter the client setattr requests for changing the size of a file.
boolean
Filter the client request for write with size change.
fpolicy_events
The information that a FPolicy process needs to determine what file access operations to monitor and for which of the monitored events notifications should be sent to the external FPolicy server.
file_operations
file_operations
filters
filters
boolean
Specifies whether failed file operations monitoring is required.
name
string
Specifies the name of the FPolicy event.
protocol
string
Protocol for which event is created. If you specify protocol, then you must also specify a valid value for the file operation parameters. The value of this parameter must be one of the following:
  • cifs - for the CIFS protocol.
  • nfsv3 - for the NFSv3 protocol.
  • nfsv4 - for the NFSv4 protocol.
volume_monitoring
boolean
Specifies whether volume operation monitoring is required.
fpolicy_engine_reference
_links
_links
name
string
The name of the FPolicy external engine.
fpolicy_event_reference
FPolicy events
_links
_links
name
string
scope
boolean
Specifies whether the file name extension checks also apply to directory objects. If this parameter is set to true, the directory objects are subjected to the same extension checks as regular files. If this parameter is set to false, the directory names are not matched for extensions and notifications are sent for directories even if their name extensions do not match. Default is false.
array[string]
exclude_extension
array[string]
exclude_shares
array[string]
exclude_volumes
array[string]
array[string]
include_extension
array[string]
include_shares
array[string]
include_volumes
array[string]
boolean
Specifies whether the extension checks also apply to objects with no extension. If this parameter is set to true, all objects with or without extensions are monitored. Default is false.
fpolicy_policies
boolean
Specifies whether privileged access is required for FPolicy servers. Privileged access is used when the FPolicy server requires direct access to the cluster nodes. When this parameter is set to true, FPolicy servers can access files on the cluster using a separate data channel with privileged access.
enabled
boolean
Specifies if the policy is enabled on the SVM or not. If no value is mentioned for this field but priority is set, then this policy will be enabled.
engine
events
array[fpolicy_event_reference]
mandatory
boolean
Specifies what action to take on a file access event in a case when all primary and secondary servers are down or no response is received from the FPolicy servers within a given timeout period. When this parameter is set to true, file access events will be denied under these circumstances.
name
string
Specifies the name of the policy.
passthrough_read
boolean
Specifies whether passthrough-read should be allowed for FPolicy servers registered for the policy. Passthrough-read is a way to read data for offline files without restoring the files to primary storage. Offline files are files that have been moved to secondary storage.
priority
integer
Specifies the priority that is assigned to this policy.
privileged_user
string
Specifies the privileged user name for accessing files on the cluster using a separate data channel with privileged access. The input for this field should be in "domain\username" format.
scope
scope
svm
_links
_links
name
string
The name of the SVM.
uuid
string
fpolicy
FPolicy is an infrastructure component of ONTAP that enables partner applications connected to your storage systems to monitor and set file access permissions. Every time a client accesses a file from a storage system, based on the configuration of FPolicy, the partner application is notified about file access.
_links
_links
engines
array[fpolicy_engines]
events
array[fpolicy_events]
policies
array[fpolicy_policies]
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
