Retrieve an FPolicy configuration
Retrieves an FPolicy configuration to review the policy settings applied to file operations within your storage environment. This helps you ensure compliance and optimize file access security measures.
HTTP method and endpoint
GET /protocols/fpolicy
Introduced in
ONTAP 9.6
Related ONTAP commands
fpolicy show -
fpolicy policy show -
fpolicy policy scope show -
fpolicy policy event show -
fpolicy policy external-engine show
Learn more
events.file_operations.create |
boolean |
query |
False |
Filter by events.file_operations.create |
events.file_operations.create_dir |
boolean |
query |
False |
Filter by events.file_operations.create_dir |
events.file_operations.open |
boolean |
query |
False |
Filter by events.file_operations.open |
events.file_operations.lookup |
boolean |
query |
False |
Filter by events.file_operations.lookup |
events.file_operations.delete |
boolean |
query |
False |
Filter by events.file_operations.delete |
events.file_operations.symlink |
boolean |
query |
False |
Filter by events.file_operations.symlink |
events.file_operations.write |
boolean |
query |
False |
Filter by events.file_operations.write |
events.file_operations.close |
boolean |
query |
False |
Filter by events.file_operations.close |
events.file_operations.read |
boolean |
query |
False |
Filter by events.file_operations.read |
events.file_operations.rename |
boolean |
query |
False |
Filter by events.file_operations.rename |
events.file_operations.rename_dir |
boolean |
query |
False |
Filter by events.file_operations.rename_dir |
events.file_operations.setattr |
boolean |
query |
False |
Filter by events.file_operations.setattr |
events.file_operations.link |
boolean |
query |
False |
Filter by events.file_operations.link |
events.file_operations.delete_dir |
boolean |
query |
False |
Filter by events.file_operations.delete_dir |
events.file_operations.getattr |
boolean |
query |
False |
Filter by events.file_operations.getattr |
events.name |
string |
query |
False |
Filter by events.name |
events.filters.setattr_with_sacl_change |
boolean |
query |
False |
Filter by events.filters.setattr_with_sacl_change |
events.filters.setattr_with_size_change |
boolean |
query |
False |
Filter by events.filters.setattr_with_size_change |
events.filters.setattr_with_mode_change |
boolean |
query |
False |
Filter by events.filters.setattr_with_mode_change |
events.filters.close_with_read |
boolean |
query |
False |
Filter by events.filters.close_with_read |
events.filters.open_with_delete_intent |
boolean |
query |
False |
Filter by events.filters.open_with_delete_intent |
events.filters.setattr_with_modify_time_change |
boolean |
query |
False |
Filter by events.filters.setattr_with_modify_time_change |
events.filters.monitor_ads |
boolean |
query |
False |
Filter by events.filters.monitor_ads |
events.filters.setattr_with_dacl_change |
boolean |
query |
False |
Filter by events.filters.setattr_with_dacl_change |
events.filters.close_with_modification |
boolean |
query |
False |
Filter by events.filters.close_with_modification |
events.filters.write_with_size_change |
boolean |
query |
False |
Filter by events.filters.write_with_size_change |
events.filters.setattr_with_creation_time_change |
boolean |
query |
False |
Filter by events.filters.setattr_with_creation_time_change |
events.filters.first_read |
boolean |
query |
False |
Filter by events.filters.first_read |
events.filters.setattr_with_group_change |
boolean |
query |
False |
Filter by events.filters.setattr_with_group_change |
events.filters.setattr_with_allocation_size_change |
boolean |
query |
False |
Filter by events.filters.setattr_with_allocation_size_change |
events.filters.open_with_write_intent |
boolean |
query |
False |
Filter by events.filters.open_with_write_intent |
events.filters.offline_bit |
boolean |
query |
False |
Filter by events.filters.offline_bit |
events.filters.setattr_with_owner_change |
boolean |
query |
False |
Filter by events.filters.setattr_with_owner_change |
events.filters.exclude_directory |
boolean |
query |
False |
Filter by events.filters.exclude_directory |
events.filters.first_write |
boolean |
query |
False |
Filter by events.filters.first_write |
events.filters.setattr_with_access_time_change |
boolean |
query |
False |
Filter by events.filters.setattr_with_access_time_change |
events.filters.close_without_modification |
boolean |
query |
False |
Filter by events.filters.close_without_modification |
events.volume_monitoring |
boolean |
query |
False |
Filter by events.volume_monitoring |
events.protocol |
string |
query |
False |
Filter by events.protocol |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
policies.mandatory |
boolean |
query |
False |
Filter by policies.mandatory |
policies.events.name |
string |
query |
False |
Filter by policies.events.name |
policies.enabled |
boolean |
query |
False |
Filter by policies.enabled |
policies.scope.check_extensions_on_directories |
boolean |
query |
False |
Filter by policies.scope.check_extensions_on_directories
policies.scope.include_volumes |
string |
query |
False |
Filter by policies.scope.include_volumes |
policies.scope.include_extension |
string |
query |
False |
Filter by policies.scope.include_extension |
policies.scope.exclude_volumes |
string |
query |
False |
Filter by policies.scope.exclude_volumes |
policies.scope.include_export_policies |
string |
query |
False |
Filter by policies.scope.include_export_policies |
policies.scope.exclude_shares |
string |
query |
False |
Filter by policies.scope.exclude_shares |
policies.scope.exclude_export_policies |
string |
query |
False |
Filter by policies.scope.exclude_export_policies |
policies.scope.object_monitoring_with_no_extension |
boolean |
query |
False |
Filter by policies.scope.object_monitoring_with_no_extension
policies.scope.include_shares |
string |
query |
False |
Filter by policies.scope.include_shares |
policies.scope.exclude_extension |
string |
query |
False |
Filter by policies.scope.exclude_extension |
policies.name |
string |
query |
False |
Filter by policies.name |
policies.passthrough_read |
boolean |
query |
False |
Filter by policies.passthrough_read
policies.privileged_user |
string |
query |
False |
Filter by policies.privileged_user
policies.engine.name |
string |
query |
False |
Filter by policies.engine.name |
policies.priority |
integer |
query |
False |
Filter by policies.priority
engines.certificate.serial_number |
string |
query |
False |
Filter by engines.certificate.serial_number
engines.certificate.name |
string |
query |
False |
Filter by engines.certificate.name
engines.certificate.ca |
string |
query |
False |
Filter by engines.certificate.ca
engines.request_abort_timeout |
string |
query |
False |
Filter by engines.request_abort_timeout
engines.max_server_requests |
integer |
query |
False |
Filter by engines.max_server_requests
engines.buffer_size.recv_buffer |
integer |
query |
False |
Filter by engines.buffer_size.recv_buffer
engines.buffer_size.send_buffer |
integer |
query |
False |
Filter by engines.buffer_size.send_buffer
engines.ssl_option |
string |
query |
False |
Filter by engines.ssl_option
engines.server_progress_timeout |
string |
query |
False |
Filter by engines.server_progress_timeout
engines.format |
string |
query |
False |
Filter by engines.format
engines.secondary_servers |
string |
query |
False |
Filter by engines.secondary_servers |
engines.port |
integer |
query |
False |
Filter by engines.port |
engines.type |
string |
query |
False |
Filter by engines.type |
engines.status_request_interval |
string |
query |
False |
Filter by engines.status_request_interval
engines.resiliency.enabled |
boolean |
query |
False |
Filter by engines.resiliency.enabled
engines.resiliency.retention_duration |
string |
query |
False |
Filter by engines.resiliency.retention_duration
engines.resiliency.directory_path |
string |
query |
False |
Filter by engines.resiliency.directory_path
engines.name |
string |
query |
False |
Filter by engines.name |
engines.request_cancel_timeout |
string |
query |
False |
Filter by engines.request_cancel_timeout
engines.primary_servers |
string |
query |
False |
Filter by engines.primary_servers |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[fpolicy] |
"next": {
"href": "/api/resourcelink"
"records": [
"engines": [
"certificate": {
"ca": "TASample1",
"name": "Sample1-FPolicy-Client",
"serial_number": "8DDE112A114D1FBC"
"format": "string",
"max_server_requests": 500,
"name": "fp_ex_eng",
"port": 9876,
"primary_servers": [
"10.132.145.20",
"10.140.101.109"
"request_abort_timeout": "PT40S",
"request_cancel_timeout": "PT20S",
"resiliency": {
"directory_path": "/dir1",
"retention_duration": "PT3M"
"secondary_servers": [
"10.132.145.20",
"10.132.145.21"
"server_progress_timeout": "PT1M",
"ssl_option": "string",
"status_request_interval": "PT10S",
"type": "string"
"events": [
"name": "event_nfs_close",
"protocol": "string"
"policies": [
"engine": {
"name": "string"
"events": [
"event_nfs_close",
"event_open"
"name": "fp_policy_1",
"privileged_user": "mydomain\\testuser",
"scope": {
"exclude_export_policies": [
"string"
"exclude_extension": [
"string"
"exclude_shares": [
"string"
"exclude_volumes": [
"vol1",
"vol_svm1",
"include_export_policies": [
"string"
"include_extension": [
"string"
"include_shares": [
"sh1",
"share_cifs"
"include_volumes": [
"vol1",
"vol_svm1"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
buffer_size
Specifies the send and recieve buffer size of the connected socket for the FPolicy server.
recv_buffer |
integer |
Specifies the receive buffer size of the connected socket for the FPolicy server. Default value is 256KB. |
send_buffer |
integer |
Specifies the send buffer size of the connected socket for the FPolicy server. Default value 1MB. |
certificate
Provides details about certificate used to authenticate the Fpolicy server.
ca |
string |
Specifies the certificate authority (CA) name of the certificate used for authentication if SSL authentication between the SVM and the FPolicy server is configured. |
name |
string |
Specifies the certificate name as a fully qualified domain name (FQDN) or custom common name. The certificate is used if SSL authentication between the SVM and the FPolicy server is configured. |
serial_number |
string |
Specifies the serial number of the certificate used for authentication if SSL authentication between the SVM and the FPolicy server is configured. |
resiliency
If all primary and secondary servers are down, or if no response is received from the FPolicy servers, file access events are stored inside the storage controller under the specified resiliency-directory-path.
directory_path |
string |
Specifies the directory path under the SVM namespace, where notifications are stored in the files whenever a network outage happens. |
enabled |
boolean |
Specifies whether the resiliency feature is enabled or not. Default is false. |
string |
Specifies the ISO-8601 duration, for which the notifications are written to files inside the storage controller during a network outage. The value for this field must be between 0 and 600 seconds. Default is 180 seconds. |
fpolicy_engines
Defines how ONTAP makes and manages connections to external FPolicy servers.
buffer_size |
Specifies the send and recieve buffer size of the connected socket for the FPolicy server. |
certificate |
Provides details about certificate used to authenticate the Fpolicy server. |
format |
string |
The format for the notification messages sent to the FPolicy servers. The possible values are:
integer |
Specifies the maximum number of outstanding requests for the FPolicy server. It is used to specify maximum outstanding requests that will be queued up for the FPolicy server. The value for this field must be between 1 and 10000. The default value can be 500 , 1000 or 2000 depending on the hardware platform. |
name |
string |
Specifies the name to assign to the external server configuration. |
port |
integer |
Port number of the FPolicy server application. |
primary_servers |
array[string] |
string |
Specifies the ISO-8601 timeout duration for a screen request to be aborted by a storage appliance. The allowed range is between 0 to 200 seconds. |
string |
Specifies the ISO-8601 timeout duration for a screen request to be processed by an FPolicy server. The allowed range is between 0 to 100 seconds. |
resiliency |
If all primary and secondary servers are down, or if no response is received from the FPolicy servers, file access events are stored inside the storage controller under the specified resiliency-directory-path. |
secondary_servers |
array[string] |
string |
Specifies the ISO-8601 timeout duration in which a throttled FPolicy server must complete at least one screen request. If no request is processed within the timeout, connection to the FPolicy server is terminated. The allowed range is between 0 to 100 seconds. |
ssl_option |
string |
Specifies the SSL option for external communication with the FPolicy server. Possible values include the following:
string |
Specifies the ISO-8601 interval time for a storage appliance to query a status request from an FPolicy server. The allowed range is between 0 to 50 seconds. |
type |
string |
The notification mode determines what ONTAP does after sending notifications to FPolicy servers. The possible values are:
file_operations
Specifies the file operations for the FPolicy event. You must specify a valid protocol in the protocol parameter. The event will check the operations specified from all client requests using the protocol.
close |
boolean |
File close operations |
create |
boolean |
File create operations |
create_dir |
boolean |
Directory create operations |
delete |
boolean |
File delete operations |
delete_dir |
boolean |
Directory delete operations |
getattr |
boolean |
Get attribute operations |
link |
boolean |
Link operations |
lookup |
boolean |
Lookup operations |
open |
boolean |
File open operations |
read |
boolean |
File read operations |
rename |
boolean |
File rename operations |
rename_dir |
boolean |
Directory rename operations |
setattr |
boolean |
Set attribute operations |
symlink |
boolean |
Symbolic link operations |
write |
boolean |
File write operations |
filters
Specifies the list of filters for a given file operation for the specified protocol. When you specify the filters, you must specify the valid protocols and a valid file operations.
boolean |
Filter the client request for close with modification. |
close_with_read |
boolean |
Filter the client request for close with read. |
boolean |
Filter the client request for close without modification. |
exclude_directory |
boolean |
Filter the client requests for directory operations. When this filter is specified directory operations are not monitored. |
first_read |
boolean |
Filter the client requests for the first-read. |
first_write |
boolean |
Filter the client requests for the first-write. |
monitor_ads |
boolean |
Filter the client request for alternate data stream. |
offline_bit |
boolean |
Filter the client request for offline bit set. FPolicy server receives notification only when offline files are accessed. |
boolean |
Filter the client request for open with delete intent. |
boolean |
Filter the client request for open with write intent. |
boolean |
Filter the client setattr requests for changing the access time of a file or directory. |
boolean |
Filter the client setattr requests for changing the allocation size of a file. |
boolean |
Filter the client setattr requests for changing the creation time of a file or directory. |
boolean |
Filter the client setattr requests for changing dacl on a file or directory. |
boolean |
Filter the client setattr requests for changing group of a file or directory. |
boolean |
Filter the client setattr requests for changing the mode bits on a file or directory. |
boolean |
Filter the client setattr requests for changing the modification time of a file or directory. |
boolean |
Filter the client setattr requests for changing owner of a file or directory. |
boolean |
Filter the client setattr requests for changing sacl on a file or directory. |
boolean |
Filter the client setattr requests for changing the size of a file. |
boolean |
Filter the client request for write with size change. |
fpolicy_events
The information that a FPolicy process needs to determine what file access operations to monitor and for which of the monitored events notifications should be sent to the external FPolicy server.
file_operations |
Specifies the file operations for the FPolicy event. You must specify a valid protocol in the protocol parameter. The event will check the operations specified from all client requests using the protocol. |
filters |
Specifies the list of filters for a given file operation for the specified protocol. When you specify the filters, you must specify the valid protocols and a valid file operations. |
name |
string |
Specifies the name of the FPolicy event. |
protocol |
string |
Protocol for which event is created. If you specify protocol, then you must also specify a valid value for the file operation parameters. The value of this parameter must be one of the following:
volume_monitoring |
boolean |
Specifies whether volume operation monitoring is required. |
fpolicy_engine_reference
FPolicy external engine
_links |
name |
string |
The name of the FPolicy external engine. |
fpolicy_event_reference
FPolicy events
_links |
name |
string |
scope
boolean |
Specifies whether the file name extension checks also apply to directory objects. If this parameter is set to true, the directory objects are subjected to the same extension checks as regular files. If this parameter is set to false, the directory names are not matched for extensions and notifications are sent for directories even if their name extensions do not match. Default is false. |
array[string] |
exclude_extension |
array[string] |
exclude_shares |
array[string] |
exclude_volumes |
array[string] |
array[string] |
include_extension |
array[string] |
include_shares |
array[string] |
include_volumes |
array[string] |
boolean |
Specifies whether the extension checks also apply to objects with no extension. If this parameter is set to true, all objects with or without extensions are monitored. Default is false. |
fpolicy_policies
enabled |
boolean |
Specifies if the policy is enabled on the SVM or not. If no value is mentioned for this field but priority is set, then this policy will be enabled. |
engine |
FPolicy external engine |
events |
array[fpolicy_event_reference] |
mandatory |
boolean |
Specifies what action to take on a file access event in a case when all primary and secondary servers are down or no response is received from the FPolicy servers within a given timeout period. When this parameter is set to true, file access events will be denied under these circumstances. |
name |
string |
Specifies the name of the policy. |
passthrough_read |
boolean |
Specifies whether passthrough-read should be allowed for FPolicy servers registered for the policy. Passthrough-read is a way to read data for offline files without restoring the files to primary storage. Offline files are files that have been moved to secondary storage. |
priority |
integer |
Specifies the priority that is assigned to this policy. |
privileged_user |
string |
Specifies the privileged user name for accessing files on the cluster using a separate data channel with privileged access. The input for this field should be in "domain\username" format. |
scope |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
fpolicy
FPolicy is an infrastructure component of ONTAP that enables partner applications connected to your storage systems to monitor and set file access permissions. Every time a client accesses a file from a storage system, based on the configuration of FPolicy, the partner application is notified about file access.
_links |
engines |
array[fpolicy_engines] |
events |
array[fpolicy_events] |
policies |
array[fpolicy_policies] |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
