Retrieve NDMP session details
GET /protocols/ndmp/sessions/{owner.uuid}/{session.id}
Introduced In: 9.7
Retrieves the details of a specific NDMP session.
Related ONTAP commands
vserver services ndmp probe -
system services ndmp probe
Learn more
owner.uuid  |
string  |
path  |
True  |
The NDMP node or SVM UUID based on whether NDMP is operating in node-scope or SVM-scope mode.  |
session.id  |
string  |
path  |
True  |
NDMP session identifier  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
backup_engine  |
string  |
Indicates the NDMP backup engine.  |
client_address  |
string  |
Indicates the NDMP client address.  |
client_port  |
integer  |
Indicates the NDMP client port.  |
data  |
Information about the NDMP data server.  |
data_path  |
string  |
Indicates the NDMP backup or restore path.  |
id  |
string  |
NDMP session identifier.  |
mover  |
Information about the NDMP mover.  |
node  |
scsi  |
Information about the NDMP SCSI server.  |
source_address  |
string  |
Indicates the NDMP local address on which connection was established.  |
svm  |
tape_device  |
string  |
Indicates the NDMP tape device.  |
tape_mode  |
string  |
The modes of a NDMP mover instance.  |
uuid  |
string  |
      "href": "/api/resourcelink"
  "backup_engine": "string",
  "client_address": "string",
  "data": {
    "bytes_processed": 5000,
    "connection": {
      "address": "string",
      "port": 18600,
      "type": "local"
    "operation": "backup",
    "reason": "aborted",
    "state": "halted"
  "data_path": "/vserver1/vol1",
  "id": "string",
  "mover": {
    "bytes_moved": 645120,
    "connection": {
      "port": 18600,
      "type": "local"
    "mode": "read",
    "reason": "end_of_media",
    "state": "connected"
  "node": {
    "name": "node1",
  "scsi": {
    "device_id": "string"
  "source_address": "string",
  "svm": {
    "name": "svm1",
  "tape_device": "nrst0a",
  "tape_mode": "write",
  "uuid": "string"
Status: Default
ONTAP Error Response codes
| Error code | Description |
68812802  |
The UUID is not valid.  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
ndmp_connect
Indicates the NDMP connection attributes.
address  |
string  |
Indicates the NDMP data connection address.  |
port  |
integer  |
Indicates the NDMP data connection port.  |
type  |
string  |
The different NDMP connection types.  |
ndmp_data
bytes_processed  |
integer  |
Indicates the NDMP data bytes processed.  |
connection  |
Indicates the NDMP connection attributes.  |
operation  |
string  |
Indicates the NDMP data server operation.  |
reason  |
string  |
If the NDMP mover or data server is in the paused or halted state, then this property provides additional information for the state.  |
state  |
string  |
The various states of the NDMP state machine during a backup or restore workflow.  |
ndmp_mover
bytes_moved  |
integer  |
Indicates the NDMP mover bytes moved.  |
connection  |
mode  |
string  |
reason  |
string  |
state  |
string  |
node
_links  |
name  |
string  |
uuid  |
string  |
ndmp_scsi
device_id  |
string  |
Indicates the NDMP SCSI device ID.  |
host_adapter  |
integer  |
Indicates the NDMP SCSI host adapter.  |
lun_id  |
integer  |
Indicates the NDMP SCSI LUN ID.  |
target_id  |
integer  |
Indicates the NDMP SCSI target ID.  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
