Retrieve NDMP session details
Retrieves details of a specific NDMP session. This is useful for monitoring and managing NDMP sessions to ensure proper data transfer operations.
HTTP method and endpoint
GET /protocols/ndmp/sessions/{owner.uuid}/{session.id}
Introduced in
ONTAP 9.7
Related ONTAP commands
vserver services ndmp probe -
system services ndmp probe
Learn more
owner.uuid |
string |
path |
True |
The NDMP node or SVM UUID based on whether NDMP is operating in node-scope or SVM-scope mode. |
session.id |
string |
path |
True |
NDMP session identifier |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
backup_engine |
string |
Indicates the NDMP backup engine. |
client_address |
string |
Indicates the NDMP client address. |
client_port |
integer |
Indicates the NDMP client port. |
data |
Information about the NDMP data server. |
data_path |
string |
Indicates the NDMP backup or restore path. |
id |
string |
NDMP session identifier. |
mover |
Information about the NDMP mover. |
node |
scsi |
Information about the NDMP SCSI server. |
source_address |
string |
Indicates the NDMP local address on which connection was established. |
svm |
tape_device |
string |
Indicates the NDMP tape device. |
tape_mode |
string |
The modes of a NDMP mover instance. |
uuid |
string |
"href": "/api/resourcelink"
"backup_engine": "string",
"client_address": "string",
"data": {
"bytes_processed": 5000,
"connection": {
"address": "string",
"port": 18600,
"type": "local"
"operation": "backup",
"reason": "aborted",
"state": "halted"
"data_path": "/vserver1/vol1",
"id": "string",
"mover": {
"bytes_moved": 645120,
"connection": {
"port": 18600,
"type": "local"
"mode": "read",
"reason": "end_of_media",
"state": "connected"
"node": {
"name": "node1",
"scsi": {
"device_id": "string"
"source_address": "string",
"svm": {
"name": "svm1",
"tape_device": "nrst0a",
"tape_mode": "write",
"uuid": "string"
Status: Default
ONTAP Error Response codes
| Error code | Description |
68812802 |
The UUID is not valid. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
ndmp_connect
Indicates the NDMP connection attributes.
address |
string |
Indicates the NDMP data connection address. |
port |
integer |
Indicates the NDMP data connection port. |
type |
string |
The different NDMP connection types. |
ndmp_data
bytes_processed |
integer |
Indicates the NDMP data bytes processed. |
connection |
Indicates the NDMP connection attributes. |
operation |
string |
Indicates the NDMP data server operation. |
reason |
string |
If the NDMP mover or data server is in the paused or halted state, then this property provides additional information for the state. |
state |
string |
The various states of the NDMP state machine during a backup or restore workflow. |
ndmp_mover
bytes_moved |
integer |
Indicates the NDMP mover bytes moved. |
connection |
mode |
string |
reason |
string |
state |
string |
node
_links |
name |
string |
uuid |
string |
ndmp_scsi
device_id |
string |
Indicates the NDMP SCSI device ID. |
host_adapter |
integer |
Indicates the NDMP SCSI host adapter. |
lun_id |
integer |
Indicates the NDMP SCSI LUN ID. |
target_id |
integer |
Indicates the NDMP SCSI target ID. |
svm
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
