REST API reference
Retrieve NDMP session details
Retrieves details of a specific NDMP session. This is useful for monitoring and managing NDMP sessions to ensure proper data transfer operations.
HTTP method and endpoint
GET /protocols/ndmp/sessions/{owner.uuid}/{session.id}
Introduced in
ONTAP 9.7
  • vserver services ndmp probe
  • system services ndmp probe
owner.uuid
string
path
True
The NDMP node or SVM UUID based on whether NDMP is operating in node-scope or SVM-scope mode.
session.id
string
path
True
NDMP session identifier
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
backup_engine
string
Indicates the NDMP backup engine.
client_address
string
Indicates the NDMP client address.
client_port
integer
Indicates the NDMP client port.
data
ndmp_data
Information about the NDMP data server.
data_path
string
Indicates the NDMP backup or restore path.
id
string
NDMP session identifier.
mover
ndmp_mover
Information about the NDMP mover.
node
node
scsi
ndmp_scsi
Information about the NDMP SCSI server.
source_address
string
Indicates the NDMP local address on which connection was established.
svm
svm
tape_device
string
Indicates the NDMP tape device.
tape_mode
string
The modes of a NDMP mover instance.
uuid
string
      "href": "/api/resourcelink"
  "backup_engine": "string",
  "client_address": "string",
  "data": {
    "bytes_processed": 5000,
    "connection": {
      "address": "string",
      "port": 18600,
      "type": "local"
    "operation": "backup",
    "reason": "aborted",
    "state": "halted"
  "data_path": "/vserver1/vol1",
  "id": "string",
  "mover": {
    "bytes_moved": 645120,
    "connection": {
      "port": 18600,
      "type": "local"
    "mode": "read",
    "reason": "end_of_media",
    "state": "connected"
  "node": {
    "name": "node1",
  "scsi": {
    "device_id": "string"
  "source_address": "string",
  "svm": {
    "name": "svm1",
  "tape_device": "nrst0a",
  "tape_mode": "write",
  "uuid": "string"
Status: Default
ONTAP Error Response codes
Error code Description
68812802
The UUID is not valid.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
ndmp_connect
Indicates the NDMP connection attributes.
address
string
Indicates the NDMP data connection address.
port
integer
Indicates the NDMP data connection port.
type
string
The different NDMP connection types.
ndmp_data
bytes_processed
integer
Indicates the NDMP data bytes processed.
connection
ndmp_connect
operation
string
Indicates the NDMP data server operation.
reason
string
If the NDMP mover or data server is in the paused or halted state, then this property provides additional information for the state.
state
string
The various states of the NDMP state machine during a backup or restore workflow.
ndmp_mover
bytes_moved
integer
Indicates the NDMP mover bytes moved.
connection
ndmp_connect
mode
string
reason
string
state
string
node
_links
_links
name
string
uuid
string
ndmp_scsi
device_id
string
Indicates the NDMP SCSI device ID.
host_adapter
integer
Indicates the NDMP SCSI host adapter.
lun_id
integer
Indicates the NDMP SCSI LUN ID.
target_id
integer
Indicates the NDMP SCSI target ID.
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
