Retrieve NDMP sessions
Retrieves NDMP sessions to monitor and manage ongoing data transfer processes. This helps you oversee session activities at different scopes, whether for a specific SVM or across the entire cluster.
HTTP method and endpoint
GET /protocols/ndmp/sessions
Introduced in
ONTAP 9.7
Usage notes
Retrieves a collection of NDMP sessions. In the case of SVM-scope, if this API is executed on a data IP, it displays the list of NDMP sessions under the specified SVM; otherwise it displays the list of NDMP sessions for all the SVMs under the cluster. In the case of node-scope, it displays the list of NDMP sessions for all nodes.
Related ONTAP commands
vserver services ndmp probe -
system services ndmp probe
Learn more
data.connection.port |
integer |
query |
False |
Filter by data.connection.port |
data.connection.type |
string |
query |
False |
Filter by data.connection.type |
data.connection.address |
string |
query |
False |
Filter by data.connection.address |
data.reason |
string |
query |
False |
Filter by data.reason |
data.operation |
string |
query |
False |
Filter by data.operation |
data.state |
string |
query |
False |
Filter by data.state |
data.bytes_processed |
integer |
query |
False |
Filter by data.bytes_processed |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
mover.state |
string |
query |
False |
Filter by mover.state |
mover.reason |
string |
query |
False |
Filter by mover.reason |
mover.mode |
string |
query |
False |
Filter by mover.mode |
mover.bytes_moved |
integer |
query |
False |
Filter by mover.bytes_moved |
mover.connection.port |
integer |
query |
False |
Filter by mover.connection.port |
mover.connection.type |
string |
query |
False |
Filter by mover.connection.type |
mover.connection.address |
string |
query |
False |
Filter by mover.connection.address |
data_path |
string |
query |
False |
Filter by data_path |
client_address |
string |
query |
False |
Filter by client_address |
tape_mode |
string |
query |
False |
Filter by tape_mode |
tape_device |
string |
query |
False |
Filter by tape_device |
backup_engine |
string |
query |
False |
Filter by backup_engine |
id |
string |
query |
False |
Filter by id |
scsi.lun_id |
integer |
query |
False |
Filter by scsi.lun_id |
scsi.target_id |
integer |
query |
False |
Filter by scsi.target_id |
scsi.device_id |
string |
query |
False |
Filter by scsi.device_id |
scsi.host_adapter |
integer |
query |
False |
Filter by scsi.host_adapter |
source_address |
string |
query |
False |
Filter by source_address |
client_port |
integer |
query |
False |
Filter by client_port |
uuid |
string |
query |
False |
Filter by uuid
node.uuid |
string |
query |
False |
Filter by node.uuid |
node.name |
string |
query |
False |
Filter by node.name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Records. |
records |
array[ndmp_session] |
"next": {
"href": "/api/resourcelink"
"records": [
"backup_engine": "string",
"client_address": "string",
"data": {
"bytes_processed": 5000,
"connection": {
"address": "string",
"port": 18600,
"type": "local"
"operation": "backup",
"reason": "aborted",
"state": "halted"
"data_path": "/vserver1/vol1",
"id": "string",
"mover": {
"bytes_moved": 645120,
"connection": {
"port": 18600,
"type": "local"
"mode": "read",
"reason": "end_of_media",
"state": "connected"
"node": {
"name": "node1",
"scsi": {
"device_id": "string"
"source_address": "string",
"svm": {
"name": "svm1",
"tape_device": "nrst0a",
"tape_mode": "write",
"uuid": "string"
Status: Default
ONTAP Error Response codes
| Error code | Description |
68812805 |
Failed to obtain the NDMP mode of the operation. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
ndmp_connect
Indicates the NDMP connection attributes.
address |
string |
Indicates the NDMP data connection address. |
port |
integer |
Indicates the NDMP data connection port. |
type |
string |
The different NDMP connection types. |
ndmp_data
Information about the NDMP data server.
bytes_processed |
integer |
Indicates the NDMP data bytes processed. |
connection |
Indicates the NDMP connection attributes. |
operation |
string |
Indicates the NDMP data server operation. |
reason |
string |
If the NDMP mover or data server is in the paused or halted state, then this property provides additional information for the state. |
state |
string |
The various states of the NDMP state machine during a backup or restore workflow. |
ndmp_mover
Information about the NDMP mover.
bytes_moved |
integer |
Indicates the NDMP mover bytes moved. |
connection |
mode |
string |
The modes of a NDMP mover instance. |
reason |
string |
state |
string |
node
_links |
name |
string |
uuid |
string |
ndmp_scsi
Information about the NDMP SCSI server.
device_id |
string |
Indicates the NDMP SCSI device ID. |
host_adapter |
integer |
Indicates the NDMP SCSI host adapter. |
lun_id |
integer |
Indicates the NDMP SCSI LUN ID. |
target_id |
integer |
Indicates the NDMP SCSI target ID. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
ndmp_session
_links |
backup_engine |
string |
Indicates the NDMP backup engine. |
client_address |
string |
Indicates the NDMP client address. |
client_port |
integer |
Indicates the NDMP client port. |
data |
Information about the NDMP data server. |
data_path |
string |
Indicates the NDMP backup or restore path. |
id |
string |
NDMP session identifier. |
mover |
Information about the NDMP mover. |
node |
scsi |
Information about the NDMP SCSI server. |
source_address |
string |
Indicates the NDMP local address on which connection was established. |
svm |
tape_device |
string |
Indicates the NDMP tape device. |
tape_mode |
string |
uuid |
string |
The NDMP node or SVM UUID based on whether NDMP is operating in node-scope or SVM-scope mode. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
