REST API reference
Retrieve NDMP sessions
Retrieves a list of active NDMP sessions, which can help you monitor current data transfer activities within your storage environment. Depending on the scope, you can view sessions for a specific SVM or across the entire cluster.
HTTP method and endpoint
GET /protocols/ndmp/sessions
Introduced in
ONTAP 9.7
Usage notes
Retrieves a collection of NDMP sessions. In the case of SVM-scope, if this API is executed on a data IP, it displays the list of NDMP sessions under the specified SVM; otherwise it displays the list of NDMP sessions for all the SVMs under the cluster. In the case of node-scope, it displays the list of NDMP sessions for all nodes.
  • vserver services ndmp probe
  • system services ndmp probe
data_path
string
query
False
Filter by data_path
data.bytes_processed
integer
query
False
Filter by data.bytes_processed
data.operation
string
query
False
Filter by data.operation
data.state
string
query
False
Filter by data.state
data.connection.address
string
query
False
Filter by data.connection.address
data.connection.type
string
query
False
Filter by data.connection.type
data.connection.port
integer
query
False
Filter by data.connection.port
data.reason
string
query
False
Filter by data.reason
uuid
string
query
False
Filter by uuid
  • Introduced in: 9.9
tape_mode
string
query
False
Filter by tape_mode
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
tape_device
string
query
False
Filter by tape_device
node.name
string
query
False
Filter by node.name
node.uuid
string
query
False
Filter by node.uuid
source_address
string
query
False
Filter by source_address
client_port
integer
query
False
Filter by client_port
mover.bytes_moved
integer
query
False
Filter by mover.bytes_moved
mover.mode
string
query
False
Filter by mover.mode
mover.connection.address
string
query
False
Filter by mover.connection.address
mover.connection.type
string
query
False
Filter by mover.connection.type
mover.connection.port
integer
query
False
Filter by mover.connection.port
mover.state
string
query
False
Filter by mover.state
mover.reason
string
query
False
Filter by mover.reason
scsi.host_adapter
integer
query
False
Filter by scsi.host_adapter
scsi.device_id
string
query
False
Filter by scsi.device_id
scsi.lun_id
integer
query
False
Filter by scsi.lun_id
scsi.target_id
integer
query
False
Filter by scsi.target_id
backup_engine
string
query
False
Filter by backup_engine
client_address
string
query
False
Filter by client_address
id
string
query
False
Filter by id
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of Records.
records
array[ndmp_session]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "backup_engine": "string",
      "client_address": "string",
      "data": {
        "bytes_processed": "5000",
        "connection": {
          "address": "string",
          "port": "18600",
          "type": "local"
        "operation": "backup",
        "reason": "aborted",
        "state": "halted"
      "data_path": "/vserver1/vol1",
      "id": "string",
      "mover": {
        "bytes_moved": "645120",
        "connection": {
          "port": "18600",
          "type": "local"
        "mode": "read",
        "reason": "end_of_media",
        "state": "connected"
      "node": {
        "name": "node1",
      "scsi": {
        "device_id": "string"
      "source_address": "string",
      "svm": {
        "name": "svm1",
      "tape_device": "nrst0a",
      "tape_mode": "write",
      "uuid": "string"
Status: Default
ONTAP Error Response codes
Error code Description
68812805
Failed to obtain the NDMP mode of the operation.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
ndmp_connect
Indicates the NDMP connection attributes.
address
string
Indicates the NDMP data connection address.
port
integer
Indicates the NDMP data connection port.
type
string
The different NDMP connection types.
ndmp_data
Information about the NDMP data server.
bytes_processed
integer
Indicates the NDMP data bytes processed.
connection
ndmp_connect
operation
string
Indicates the NDMP data server operation.
reason
string
If the NDMP mover or data server is in the paused or halted state, then this property provides additional information for the state.
state
string
The various states of the NDMP state machine during a backup or restore workflow.
ndmp_mover
Information about the NDMP mover.
bytes_moved
integer
Indicates the NDMP mover bytes moved.
connection
ndmp_connect
mode
string
The modes of a NDMP mover instance.
reason
string
state
string
node
_links
_links
name
string
uuid
string
ndmp_scsi
Information about the NDMP SCSI server.
device_id
string
Indicates the NDMP SCSI device ID.
host_adapter
integer
Indicates the NDMP SCSI host adapter.
lun_id
integer
Indicates the NDMP SCSI LUN ID.
target_id
integer
Indicates the NDMP SCSI target ID.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
ndmp_session
_links
_links
backup_engine
string
Indicates the NDMP backup engine.
client_address
string
Indicates the NDMP client address.
client_port
integer
Indicates the NDMP client port.
data
ndmp_data
data_path
string
Indicates the NDMP backup or restore path.
id
string
NDMP session identifier.
mover
ndmp_mover
node
node
scsi
ndmp_scsi
source_address
string
Indicates the NDMP local address on which connection was established.
svm
svm
tape_device
string
Indicates the NDMP tape device.
tape_mode
string
uuid
string
The NDMP node or SVM UUID based on whether NDMP is operating in node-scope or SVM-scope mode.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
