Retrieve NDMP sessions
Retrieves NDMP sessions to view the active data management sessions occurring within your storage system. This is useful for monitoring and managing the backup and restore operations associated with NDMP.
HTTP method and endpoint
GET /protocols/ndmp/sessions
Introduced in
ONTAP 9.7
Usage notes
Retrieves a collection of NDMP sessions. In the case of SVM-scope, if this API is executed on a data IP, it displays the list of NDMP sessions under the specified SVM; otherwise it displays the list of NDMP sessions for all the SVMs under the cluster. In the case of node-scope, it displays the list of NDMP sessions for all nodes.
Related ONTAP commands
vserver services ndmp probe -
system services ndmp probe
Learn more
node.name |
string |
query |
False |
Filter by node.name |
node.uuid |
string |
query |
False |
Filter by node.uuid |
scsi.target_id |
integer |
query |
False |
Filter by scsi.target_id |
scsi.host_adapter |
integer |
query |
False |
Filter by scsi.host_adapter |
scsi.device_id |
string |
query |
False |
Filter by scsi.device_id |
scsi.lun_id |
integer |
query |
False |
Filter by scsi.lun_id |
client_port |
integer |
query |
False |
Filter by client_port |
source_address |
string |
query |
False |
Filter by source_address |
data_path |
string |
query |
False |
Filter by data_path |
uuid |
string |
query |
False |
Filter by uuid
client_address |
string |
query |
False |
Filter by client_address |
id |
string |
query |
False |
Filter by id |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
tape_device |
string |
query |
False |
Filter by tape_device |
tape_mode |
string |
query |
False |
Filter by tape_mode |
backup_engine |
string |
query |
False |
Filter by backup_engine |
data.operation |
string |
query |
False |
Filter by data.operation |
data.connection.address |
string |
query |
False |
Filter by data.connection.address |
data.connection.type |
string |
query |
False |
Filter by data.connection.type |
data.connection.port |
integer |
query |
False |
Filter by data.connection.port |
data.state |
string |
query |
False |
Filter by data.state |
data.reason |
string |
query |
False |
Filter by data.reason |
data.bytes_processed |
integer |
query |
False |
Filter by data.bytes_processed |
mover.mode |
string |
query |
False |
Filter by mover.mode |
mover.bytes_moved |
integer |
query |
False |
Filter by mover.bytes_moved |
mover.connection.address |
string |
query |
False |
Filter by mover.connection.address |
mover.connection.type |
string |
query |
False |
Filter by mover.connection.type |
mover.connection.port |
integer |
query |
False |
Filter by mover.connection.port |
mover.state |
string |
query |
False |
Filter by mover.state |
mover.reason |
string |
query |
False |
Filter by mover.reason |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Records. |
records |
array[ndmp_session] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"backup_engine": "string",
"client_address": "string",
"data": {
"bytes_processed": 5000,
"connection": {
"address": "string",
"port": 18600,
"type": "local"
"operation": "backup",
"reason": "aborted",
"state": "halted"
"data_path": "/vserver1/vol1",
"id": "string",
"mover": {
"bytes_moved": 645120,
"connection": {
"port": 18600,
"type": "local"
"mode": "read",
"reason": "end_of_media",
"state": "connected"
"node": {
"name": "node1",
"scsi": {
"device_id": "string"
"source_address": "string",
"svm": {
"name": "svm1",
"tape_device": "nrst0a",
"tape_mode": "write",
"uuid": "string"
Status: Default
ONTAP Error Response codes
| Error code | Description |
68812805 |
Failed to obtain the NDMP mode of the operation. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
ndmp_connect
Indicates the NDMP connection attributes.
address |
string |
Indicates the NDMP data connection address. |
port |
integer |
Indicates the NDMP data connection port. |
type |
string |
The different NDMP connection types. |
ndmp_data
Information about the NDMP data server.
bytes_processed |
integer |
Indicates the NDMP data bytes processed. |
connection |
Indicates the NDMP connection attributes. |
operation |
string |
Indicates the NDMP data server operation. |
reason |
string |
If the NDMP mover or data server is in the paused or halted state, then this property provides additional information for the state. |
state |
string |
The various states of the NDMP state machine during a backup or restore workflow. |
ndmp_mover
Information about the NDMP mover.
bytes_moved |
integer |
Indicates the NDMP mover bytes moved. |
connection |
mode |
string |
The modes of a NDMP mover instance. |
reason |
string |
state |
string |
node
_links |
name |
string |
uuid |
string |
ndmp_scsi
Information about the NDMP SCSI server.
device_id |
string |
Indicates the NDMP SCSI device ID. |
host_adapter |
integer |
Indicates the NDMP SCSI host adapter. |
lun_id |
integer |
Indicates the NDMP SCSI LUN ID. |
target_id |
integer |
Indicates the NDMP SCSI target ID. |
svm
_links |
name |
string |
uuid |
string |
ndmp_session
_links |
backup_engine |
string |
Indicates the NDMP backup engine. |
client_address |
string |
Indicates the NDMP client address. |
client_port |
integer |
Indicates the NDMP client port. |
data |
Information about the NDMP data server. |
data_path |
string |
Indicates the NDMP backup or restore path. |
id |
string |
NDMP session identifier. |
mover |
Information about the NDMP mover. |
node |
scsi |
Information about the NDMP SCSI server. |
source_address |
string |
Indicates the NDMP local address on which connection was established. |
svm |
tape_device |
string |
Indicates the NDMP tape device. |
tape_mode |
string |
uuid |
string |
The NDMP node or SVM UUID based on whether NDMP is operating in node-scope or SVM-scope mode. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
