REST API reference
Generate and retrieve the password for an NDMP user
Generates and retrieves the password for an NDMP user to secure data transfer operations.
HTTP method and endpoint
GET /protocols/ndmp/svms/{svm.uuid}/passwords/{user}
Introduced in
ONTAP 9.9
Usage notes
Generates and retrieves the password for the specified NDMP user.
  • vserver services ndmp generate-password
svm.uuid
string
path
True
SVM UUID
user
string
path
True
User name
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
password
string
NDMP Password
svm
svm
user
string
NDMP user
      "href": "/api/resourcelink"
  "password": "string",
  "svm": {
    "name": "svm1",
  "user": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
