Generate and retrieve the password for an NDMP user
Generates and retrieves the password for a specified NDMP user to manage authentication for data transfer operations.
HTTP method and endpoint
GET /protocols/ndmp/svms/{svm.uuid}/passwords/{user}
Introduced in
ONTAP 9.9
Related ONTAP commands
vserver services ndmp generate-password
svm.uuid |
string |
path |
True |
SVM UUID |
user |
string |
path |
True |
User name |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
password |
string |
NDMP Password |
svm |
user |
string |
NDMP user |
"href": "/api/resourcelink"
"password": "string",
"svm": {
"name": "svm1",
"user": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
