REST API reference
Generate and retrieve the password for an NDMP user
Generates and retrieves the password for a specific NDMP user, ensuring secure access to NDMP services. Use this endpoint when you need to update or verify the password for NDMP operations.
HTTP method and endpoint
GET /protocols/ndmp/svms/{svm.uuid}/passwords/{user}
Introduced in
ONTAP 9.9
Usage notes
Generates and retrieves the password for the specified NDMP user.
  • vserver services ndmp generate-password
svm.uuid
string
path
True
SVM UUID
user
string
path
True
User name
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
password
string
NDMP Password
svm
svm
user
string
NDMP user
      "href": "/api/resourcelink"
  "password": "string",
  "svm": {
    "name": "svm1",
  "user": "string"
Status: Default
ONTAP Error Response codes
Error code Description
65601536
The operation is not supported because NDMP SVM-aware mode is disabled.
65601560
An NDMP-specific password is not supported for authentication type "plaintext_sso".
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
