Retrieve NVMe interfaces
Accesses NVMe interfaces to review their configuration and status, which can assist in managing and monitoring NVMe protocol operations within your system.
HTTP method and endpoint
GET /protocols/nvme/interfaces
Introduced in
ONTAP 9.6
Usage notes
Retrieves NVMe interfaces.
Related ONTAP commands
vserver nvme show-interface
Learn more
uuid |
string |
query |
False |
Filter by uuid |
ip_interface.location.port.name |
string |
query |
False |
Filter by ip_interface.location.port.name
ip_interface.location.port.node.name |
string |
query |
False |
Filter by ip_interface.location.port.node.name
ip_interface.location.port.uuid |
string |
query |
False |
Filter by ip_interface.location.port.uuid
ip_interface.ip.address |
string |
query |
False |
Filter by ip_interface.ip.address
node.uuid |
string |
query |
False |
Filter by node.uuid |
node.name |
string |
query |
False |
Filter by node.name |
transport_protocols |
string |
query |
False |
Filter by transport_protocols
interface_type |
string |
query |
False |
Filter by interface_type
enabled |
boolean |
query |
False |
Filter by enabled |
fc_interface.wwnn |
string |
query |
False |
Filter by fc_interface.wwnn |
fc_interface.port.name |
string |
query |
False |
Filter by fc_interface.port.name |
fc_interface.port.uuid |
string |
query |
False |
Filter by fc_interface.port.uuid |
fc_interface.port.node.name |
string |
query |
False |
Filter by fc_interface.port.node.name |
fc_interface.wwpn |
string |
query |
False |
Filter by fc_interface.wwpn |
name |
string |
query |
False |
Filter by name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
transport_address |
string |
query |
False |
Filter by transport_address |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[nvme_interface] |
"next": {
"href": "/api/resourcelink"
"records": [
"fc_interface": {
"port": {
"name": "0a",
"node": {
"name": "node1"
"wwnn": "20:00:00:50:56:b4:13:a9",
"wwpn": "20:00:00:50:56:b4:13:a8"
"interface_type": "string",
"ip_interface": {
"ip": {
"address": "10.10.10.7"
"location": {
"port": {
"name": "e1b",
"node": {
"name": "node1"
"name": "lif1",
"node": {
"name": "node1",
"svm": {
"name": "svm1",
"transport_address": "nn-0x200a00a0989062da:pn-0x200100a0989062da",
"transport_protocols": [
"string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
node
The node on which the FC port is located.
name |
string |
The name of the node on which the FC port is located. |
port
An FC port is the physical port of an FC adapter on a cluster node that can be connected to an FC network.
_links |
name |
string |
The name of the FC port. |
node |
The node on which the FC port is located. |
uuid |
string |
The unique identifier of the FC port. |
fc_interface
The attributes specific to a Fibre Channel-based NVMe interface.
This is populated when interface_type is fc_interface.
_links |
port |
An FC port is the physical port of an FC adapter on a cluster node that can be connected to an FC network. |
wwnn |
string |
The WWNN (world wide node name) of the Fibre Channel NVMe interface. |
wwpn |
string |
The WWPN (world wide port name) of the Fibre Channel NVMe interface. |
self_link
self |
ip
address |
string |
IPv4 or IPv6 address |
node
name |
string |
Name of node on which the port is located. |
port_reference
Port UUID along with readable names. Either the UUID or both names may be supplied on input.
_links |
name |
string |
node |
uuid |
string |
location
port |
Port UUID along with readable names. Either the UUID or both names may be supplied on input. |
ip_interface
The attributes specific to an IP-based NVMe interface.
This is populated when interface_type is ip_interface.
_links |
ip |
location |
node
_links |
name |
string |
uuid |
string |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
nvme_interface
NVMe interfaces are network interfaces configured to support an NVMe over Fabrics (NVMe-oF) protocol. The NVMe interfaces are Fibre Channel interfaces supporting an NVMe-oF data protocol. Regardless of the underlying physical and data protocol, NVMe interfaces are treated equally for host-side application configuration. This endpoint provides a consolidated view of all NVMe interfaces for the purpose of configuring host-side applications.
NVMe interfaces must be created using the protocol-specific endpoints for Fibre Channel interfaces. See POST /network/fc/interfaces . After creation, the interfaces are available via this interface.
_links |
enabled |
boolean |
The administrative state of the NVMe interface. |
fc_interface |
The attributes specific to a Fibre Channel-based NVMe interface. This is populated when |
interface_type |
string |
The underlying interface type of the NVMe interface. This property identifies which of fc_interface and ip_interface will be further populated. |
ip_interface |
The attributes specific to an IP-based NVMe interface. This is populated when |
name |
string |
The name of the NVMe interface. |
node |
svm |
transport_address |
string |
The transport address of the NVMe interface. |
array[string] |
The transport protocols supported by the NVMe interface. |
uuid |
string |
The unique identifier of the NVMe interface. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
