Retrieve NVMe interfaces
Retrieves NVMe interfaces to view their configurations and operational status. This helps you manage and monitor NVMe protocol connectivity within your storage environment.
HTTP method and endpoint
GET /protocols/nvme/interfaces
Introduced in
ONTAP 9.6
Related ONTAP commands
vserver nvme show-interface
Learn more
enabled |
boolean |
query |
False |
Filter by enabled |
ip_interface.ip.address |
string |
query |
False |
Filter by ip_interface.ip.address
ip_interface.location.port.uuid |
string |
query |
False |
Filter by ip_interface.location.port.uuid
ip_interface.location.port.name |
string |
query |
False |
Filter by ip_interface.location.port.name
ip_interface.location.port.node.name |
string |
query |
False |
Filter by ip_interface.location.port.node.name
interface_type |
string |
query |
False |
Filter by interface_type
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
uuid |
string |
query |
False |
Filter by uuid |
transport_address |
string |
query |
False |
Filter by transport_address |
name |
string |
query |
False |
Filter by name |
node.name |
string |
query |
False |
Filter by node.name |
node.uuid |
string |
query |
False |
Filter by node.uuid |
transport_protocols |
string |
query |
False |
Filter by transport_protocols
fc_interface.wwpn |
string |
query |
False |
Filter by fc_interface.wwpn |
fc_interface.wwnn |
string |
query |
False |
Filter by fc_interface.wwnn |
fc_interface.port.uuid |
string |
query |
False |
Filter by fc_interface.port.uuid |
fc_interface.port.name |
string |
query |
False |
Filter by fc_interface.port.name |
fc_interface.port.node.name |
string |
query |
False |
Filter by fc_interface.port.node.name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
The number of records in the response. |
records |
array[nvme_interface] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"fc_interface": {
"port": {
"name": "0a",
"node": {
"name": "node1"
"wwnn": "20:00:00:50:56:b4:13:a9",
"wwpn": "20:00:00:50:56:b4:13:a8"
"interface_type": "string",
"ip_interface": {
"ip": {
"address": "10.10.10.7"
"location": {
"port": {
"name": "e1b",
"node": {
"name": "node1"
"name": "lif1",
"node": {
"name": "node1",
"svm": {
"name": "svm1",
"transport_address": "nn-0x200a00a0989062da:pn-0x200100a0989062da",
"transport_protocols": [
"string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
node
The node on which the FC port is located.
name |
string |
The name of the node on which the FC port is located. |
port
An FC port is the physical port of an FC adapter on a cluster node that can be connected to an FC network.
_links |
name |
string |
The name of the FC port. |
node |
The node on which the FC port is located. |
uuid |
string |
The unique identifier of the FC port. |
fc_interface
The attributes specific to a Fibre Channel-based NVMe interface.
This is populated when interface_type is fc_interface.
_links |
port |
An FC port is the physical port of an FC adapter on a cluster node that can be connected to an FC network. |
wwnn |
string |
The WWNN (world wide node name) of the Fibre Channel NVMe interface. |
wwpn |
string |
The WWPN (world wide port name) of the Fibre Channel NVMe interface. |
self_link
self |
ip
address |
string |
IPv4 or IPv6 address |
node
name |
string |
Name of node on which the port is located. |
port_reference
Port UUID along with readable names. Either the UUID or both names may be supplied on input.
_links |
name |
string |
node |
uuid |
string |
location
port |
Port UUID along with readable names. Either the UUID or both names may be supplied on input. |
ip_interface
The attributes specific to an IP-based NVMe interface.
This is populated when interface_type is ip_interface.
_links |
ip |
location |
node
_links |
name |
string |
uuid |
string |
svm
_links |
name |
string |
uuid |
string |
nvme_interface
NVMe interfaces are network interfaces configured to support an NVMe over Fabrics (NVMe-oF) protocol. The NVMe interfaces are Fibre Channel interfaces supporting an NVMe-oF data protocol. Regardless of the underlying physical and data protocol, NVMe interfaces are treated equally for host-side application configuration. This endpoint provides a consolidated view of all NVMe interfaces for the purpose of configuring host-side applications.
NVMe interfaces must be created using the protocol-specific endpoints for Fibre Channel interfaces. See POST /network/fc/interfaces . After creation, the interfaces are available via this interface.
_links |
enabled |
boolean |
The administrative state of the NVMe interface. |
fc_interface |
The attributes specific to a Fibre Channel-based NVMe interface. This is populated when |
interface_type |
string |
The underlying interface type of the NVMe interface. This property identifies which of fc_interface and ip_interface will be further populated. |
ip_interface |
The attributes specific to an IP-based NVMe interface. This is populated when |
name |
string |
The name of the NVMe interface. |
node |
svm |
transport_address |
string |
The transport address of the NVMe interface. |
array[string] |
The transport protocols supported by the NVMe interface. |
uuid |
string |
The unique identifier of the NVMe interface. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
