Retrieve NVMe interfaces
GET /protocols/nvme/interfaces
Retrieves NVMe interfaces.
Related ONTAP commands
vserver nvme show-interface
Learn more
name  |
string  |
query  |
False  |
Filter by name  |
transport_address  |
string  |
query  |
False  |
Filter by transport_address  |
svm.uuid  |
string  |
query  |
False  |
Filter by svm.uuid  |
svm.name  |
string  |
query  |
False  |
Filter by svm.name  |
uuid  |
string  |
query  |
False  |
Filter by uuid  |
node.uuid  |
string  |
query  |
False  |
Filter by node.uuid  |
node.name  |
string  |
query  |
False  |
Filter by node.name  |
fc_interface.wwpn  |
string  |
query  |
False  |
Filter by fc_interface.wwpn  |
fc_interface.wwnn  |
string  |
query  |
False  |
Filter by fc_interface.wwnn  |
fc_interface.port.name  |
string  |
query  |
False  |
Filter by fc_interface.port.name  |
fc_interface.port.node.name  |
string  |
query  |
False  |
Filter by fc_interface.port.node.name  |
fc_interface.port.uuid  |
string  |
query  |
False  |
Filter by fc_interface.port.uuid  |
enabled  |
boolean  |
query  |
False  |
Filter by enabled  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
max_records  |
integer  |
query  |
False  |
Limit the number of records returned.  |
return_records  |
boolean  |
query  |
False  |
The default is true for GET calls. When set to false, only the number of records is returned.  |
return_timeout  |
integer  |
query  |
False  |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached.  |
order_by  |
array[string]  |
query  |
False  |
Order results by specified fields and optional [asc  |
Status: 200, Ok
| Name | Type | Description |
_links  |
num_records  |
integer  |
Number of records.  |
records  |
array[nvme_interface]  |
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "fc_interface": {
        "port": {
          "name": "0a",
          "node": {
            "name": "node1"
        "wwnn": "20:00:00:50:56:b4:13:a9",
        "wwpn": "20:00:00:50:56:b4:13:a8"
      "name": "lif1",
      "node": {
        "name": "node1",
      "svm": {
        "name": "svm1",
      "transport_address": "nn-0x200a00a0989062da:pn-0x200100a0989062da",
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
next  |
self  |
_links
self  |
node
The node on which the FC port is located.
name  |
string  |
The name of the node on which the FC port is located.  |
port
An FC port is the physical port of an FC adapter on a cluster node that can be connected to an FC network.
_links  |
name  |
string  |
The name of the FC port.  |
node  |
The node on which the FC port is located.  |
uuid  |
string  |
The unique identifier of the FC port.  |
fc_interface
The attributes specific to a Fibre Channel-based NVMe interface.
_links  |
port  |
An FC port is the physical port of an FC adapter on a cluster node that can be connected to an FC network.  |
wwnn  |
string  |
The WWNN (world wide node name) of the Fibre Channel NVMe interface.  |
wwpn  |
string  |
The WWPN (world wide port name) of the Fibre Channel NVMe interface.  |
node
_links  |
name  |
string  |
uuid  |
string  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
nvme_interface
NVMe interfaces are network interfaces configured to support an NVMe over Fabrics (NVMe-oF) protocol. The NVMe interfaces are Fibre Channel interfaces supporting an NVMe-oF data protocol. Regardless of the underlying physical and data protocol, NVMe interfaces are treated equally for host-side application configuration. This endpoint provides a consolidated view of all NVMe interfaces for the purpose of configuring host-side applications.
NVMe interfaces must be created using the protocol-specific endpoints for Fibre Channel interfaces. See POST /network/fc/interfaces . After creation, the interfaces are available via this interface.
_links  |
enabled  |
boolean  |
The administrative state of the NVMe interface.  |
fc_interface  |
The attributes specific to a Fibre Channel-based NVMe interface.  |
name  |
string  |
The name of the NVMe interface.  |
node  |
svm  |
transport_address  |
string  |
The transport address of the NVMe interface.  |
uuid  |
string  |
The unique identifier of the NVMe interface.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
