REST API reference
Retrieve NVMe interfaces
Retrieves NVMe interfaces to view the available configurations for NVMe protocol communication.
HTTP method and endpoint
GET /protocols/nvme/interfaces
Introduced in
ONTAP 9.6
  • vserver nvme show-interface
fc_interface.port.node.name
string
query
False
Filter by fc_interface.port.node.name
fc_interface.port.uuid
string
query
False
Filter by fc_interface.port.uuid
fc_interface.port.name
string
query
False
Filter by fc_interface.port.name
fc_interface.wwpn
string
query
False
Filter by fc_interface.wwpn
fc_interface.wwnn
string
query
False
Filter by fc_interface.wwnn
transport_address
string
query
False
Filter by transport_address
name
string
query
False
Filter by name
enabled
boolean
query
False
Filter by enabled
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
node.name
string
query
False
Filter by node.name
node.uuid
string
query
False
Filter by node.uuid
uuid
string
query
False
Filter by uuid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records.
records
array[nvme_interface]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "fc_interface": {
        "port": {
          "name": "0a",
          "node": {
            "name": "node1"
        "wwnn": "20:00:00:50:56:b4:13:a9",
        "wwpn": "20:00:00:50:56:b4:13:a8"
      "name": "lif1",
      "node": {
        "name": "node1",
      "svm": {
        "name": "svm1",
      "transport_address": "nn-0x200a00a0989062da:pn-0x200100a0989062da",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
node
The node on which the FC port is located.
name
string
The name of the node on which the FC port is located.
port
An FC port is the physical port of an FC adapter on a cluster node that can be connected to an FC network.
_links
_links
name
string
The name of the FC port.
node
node
uuid
string
The unique identifier of the FC port.
fc_interface
The attributes specific to a Fibre Channel-based NVMe interface.
_links
_links
port
port
wwnn
string
The WWNN (world wide node name) of the Fibre Channel NVMe interface.
wwpn
string
The WWPN (world wide port name) of the Fibre Channel NVMe interface.
node
_links
_links
name
string
uuid
string
svm
_links
_links
name
string
The name of the SVM.
uuid
string
nvme_interface
NVMe interfaces are network interfaces configured to support an NVMe over Fabrics (NVMe-oF) protocol. The NVMe interfaces are Fibre Channel interfaces supporting an NVMe-oF data protocol. Regardless of the underlying physical and data protocol, NVMe interfaces are treated equally for host-side application configuration. This endpoint provides a consolidated view of all NVMe interfaces for the purpose of configuring host-side applications.
NVMe interfaces must be created using the protocol-specific endpoints for Fibre Channel interfaces. See POST /network/fc/interfaces . After creation, the interfaces are available via this interface.
_links
_links
enabled
boolean
The administrative state of the NVMe interface.
fc_interface
fc_interface
name
string
The name of the NVMe interface.
node
node
svm
svm
transport_address
string
The transport address of the NVMe interface.
uuid
string
The unique identifier of the NVMe interface.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
