Retrieve NVMe subsystems
Retrieves NVMe subsystems to access their configuration and management details. This is useful for monitoring and maintaining NVMe storage resources within your environment.
HTTP method and endpoint
GET /protocols/nvme/subsystems
Introduced in
ONTAP 9.6
Related ONTAP commands
vserver nvme subsystem host show -
vserver nvme subsystem map show -
vserver nvme subsystem show
Learn more
hosts.nqn |
string |
query |
False |
Filter by hosts.nqn |
name |
string |
query |
False |
Filter by name |
delete_on_unmap |
boolean |
query |
False |
Filter by delete_on_unmap
target_nqn |
string |
query |
False |
Filter by target_nqn |
io_queue.default.count |
integer |
query |
False |
Filter by io_queue.default.count |
io_queue.default.depth |
integer |
query |
False |
Filter by io_queue.default.depth |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
serial_number |
string |
query |
False |
Filter by serial_number |
uuid |
string |
query |
False |
Filter by uuid |
subsystem_maps.namespace.uuid |
string |
query |
False |
Filter by subsystem_maps.namespace.uuid |
subsystem_maps.namespace.name |
string |
query |
False |
Filter by subsystem_maps.namespace.name |
subsystem_maps.anagrpid |
string |
query |
False |
Filter by subsystem_maps.anagrpid |
subsystem_maps.nsid |
string |
query |
False |
Filter by subsystem_maps.nsid |
os_type |
string |
query |
False |
Filter by os_type |
comment |
string |
query |
False |
Filter by comment |
vendor_uuids |
string |
query |
False |
Filter by vendor_uuids
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[nvme_subsystem] |
"next": {
"href": "/api/resourcelink"
"records": [
"comment": "string",
"hosts": [
"nqn": "nqn.1992-01.example.com:string"
"io_queue": {
"default": {
"count": 4,
"depth": 16
"name": "subsystem1",
"os_type": "string",
"serial_number": "wCVsgFMiuMhVAAAAAAAB",
"subsystem_maps": [
"anagrpid": "00103050h",
"namespace": {
"name": "/vol/vol1/namespace1",
"nsid": "00000001h"
"svm": {
"name": "svm1",
"target_nqn": "nqn.1992-01.example.com:string",
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
"vendor_uuids": [
"1447f0f4-42e5-0dfc-871a-dc9b3f92d8f8"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
hosts
nqn |
string |
The NVMe qualified name (NQN) used to identify the NVMe storage target. |
default
The default I/O queue parameters inherited by NVMe hosts in the NVMe subsystem.
count |
integer |
The number of host I/O queue pairs. |
depth |
integer |
The host I/O queue depth. |
io_queue
The properties of the submission queue used to submit I/O commands for execution by the NVMe controller.
default |
The default I/O queue parameters inherited by NVMe hosts in the NVMe subsystem. |
namespace
An NVMe namespace mapped to the NVMe subsystem.
_links |
name |
string |
The name of the NVMe namespace. |
uuid |
string |
The unique identifier of the NVMe namespace. |
subsystem_maps
_links |
anagrpid |
string |
The Asymmetric Namespace Access Group ID (ANAGRPID) of the NVMe namespace. The format for an ANAGRPIP is 8 hexadecimal digits (zero-filled) followed by a lower case "h". |
namespace |
An NVMe namespace mapped to the NVMe subsystem. |
nsid |
string |
The NVMe namespace identifier. This is an identifier used by an NVMe controller to provide access to the NVMe namespace. The format for an NVMe namespace identifier is 8 hexadecimal digits (zero-filled) followed by a lower case "h". |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
nvme_subsystem
An NVMe subsystem maintains configuration state and namespace access control for a set of NVMe-connected hosts.
_links |
comment |
string |
A configurable comment for the NVMe subsystem. Optional in POST and PATCH. |
delete_on_unmap |
boolean |
An option that causes the subsystem to be deleted when the last subsystem map associated with it is deleted. This property defaults to false when the subsystem is created. |
hosts |
array[hosts] |
The NVMe hosts configured for access to the NVMe subsystem. Optional in POST. |
io_queue |
The properties of the submission queue used to submit I/O commands for execution by the NVMe controller. |
name |
string |
The name of the NVMe subsystem. Once created, an NVMe subsystem cannot be renamed. Required in POST. |
os_type |
string |
The host operating system of the NVMe subsystem's hosts. Required in POST. |
serial_number |
string |
The serial number of the NVMe subsystem. |
subsystem_maps |
array[subsystem_maps] |
The NVMe namespaces mapped to the NVMe subsystem. There is an added cost to retrieving property values for |
svm |
target_nqn |
string |
uuid |
string |
The unique identifier of the NVMe subsystem. |
vendor_uuids |
array[string] |
Vendor-specific identifiers (UUIDs) optionally assigned to an NVMe subsystem when the subsystem is created. The identifiers are used to enable vendor-specific NVMe protocol features. The identifiers are provided by a host application vendor and shared with NetApp prior to a joint product release. Creating an NVMe subsystem with an unknown or non-specific identifier will have no effect on the NVMe subsystem. Refer to the ONTAP SAN Administration Guide for a list of the supported vendor-specific identifiers. After a subsystem is created, the vendor-specific identifiers cannot be changed or removed. Optional in POST.
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
