REST API reference
Retrieve NVMe subsystems
Accesses NVMe subsystems, gaining insight into their configurations and status for management and troubleshooting purposes.
HTTP method and endpoint
GET /protocols/nvme/subsystems
Introduced in
ONTAP 9.6
Usage notes
Retrieves NVMe subsystems.
  • vserver nvme subsystem host show
  • vserver nvme subsystem map show
  • vserver nvme subsystem show
hosts.tls.key_type
string
query
False
Filter by hosts.tls.key_type
  • Introduced in: 9.16
hosts.priority
string
query
False
Filter by hosts.priority
  • Introduced in: 9.14
hosts.nqn
string
query
False
Filter by hosts.nqn
hosts.dh_hmac_chap.group_size
string
query
False
Filter by hosts.dh_hmac_chap.group_size
  • Introduced in: 9.12
hosts.dh_hmac_chap.mode
string
query
False
Filter by hosts.dh_hmac_chap.mode
hosts.dh_hmac_chap.hash_function
string
query
False
Filter by hosts.dh_hmac_chap.hash_function
vendor_uuids
string
query
False
Filter by vendor_uuids
  • Introduced in: 9.9
name
string
query
False
Filter by name
  • maxLength: 64
  • minLength: 1
serial_number
string
query
False
Filter by serial_number
  • maxLength: 20
  • minLength: 20
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
delete_on_unmap
boolean
query
False
Filter by delete_on_unmap
  • Introduced in: 9.7
comment
string
query
False
Filter by comment
  • maxLength: 255
  • minLength: 0
subsystem_maps.nsid
string
query
False
Filter by subsystem_maps.nsid
subsystem_maps.anagrpid
string
query
False
Filter by subsystem_maps.anagrpid
subsystem_maps.namespace.name
string
query
False
Filter by subsystem_maps.namespace.name
subsystem_maps.namespace.uuid
string
query
False
Filter by subsystem_maps.namespace.uuid
target_nqn
string
query
False
Filter by target_nqn
  • maxLength: 223
  • minLength: 1
os_type
string
query
False
Filter by os_type
io_queue.default.count
integer
query
False
Filter by io_queue.default.count
  • Max value: 15
  • Min value: 1
io_queue.default.depth
integer
query
False
Filter by io_queue.default.depth
  • Max value: 128
  • Min value: 16
uuid
string
query
False
Filter by uuid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
The number of records in the response.
records
array[nvme_subsystem]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "comment": "string",
      "hosts": [
          "dh_hmac_chap": {
            "group_size": "string",
            "hash_function": "string",
            "mode": "bidirectional"
          "nqn": "nqn.1992-01.example.com:string",
          "priority": "string",
          "tls": {
            "key_type": "configured"
      "io_queue": {
        "default": {
          "count": 4,
          "depth": 16
      "name": "subsystem1",
      "os_type": "string",
      "serial_number": "wCVsgFMiuMhVAAAAAAAB",
      "subsystem_maps": [
          "anagrpid": "00103050h",
          "namespace": {
            "name": "/vol/vol1/namespace1",
          "nsid": "00000001h"
      "svm": {
        "name": "svm1",
      "target_nqn": "nqn.1992-01.example.com:string",
      "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
      "vendor_uuids": [
        "1447f0f4-42e5-0dfc-871a-dc9b3f92d8f8"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
dh_hmac_chap
A container for the configuration of NVMe in-band authentication using the DH-HMAC-CHAP protocol for a host.
group_size
string
The Diffie-Hellman group size for NVMe in-band authentication. When property host_secret_key is provided, this property defaults to 2048_bit. When supplied, the property host_secret_key must also be supplied. Optional in POST.
hash_function
string
The hash function for NVMe in-band authentication. When property host_secret_key is provided, this property defaults to sha_256. When supplied, the property host_secret_key must also be supplied. Optional in POST.
mode
string
The expected NVMe in-band authentication mode for the host. This property is an indication of which secrets are configured for the host. When set to:
  • none: The host has neither the host nor controller secret configured, and no authentication is performed.
  • unidirectional: The host has a host secret configured. The controller will authenticate the host.
  • bidirectional: The host has both a host and controller secret configured. The controller will authenticate the host and the host will authenticate the controller.
tls
A container for the configuration for NVMe/TCP-TLS transport session for the host.
key_type
string
The method by which the TLS pre-shared key (PSK) is configured for the host. Optional in POST.
The values for property key_type and property configured_psk must logically agree.
Possible values:
  • none - TLS is not configured for the host connection. No value is allowed for property configured_psk.
  • configured - A user supplied PSK is configured for the NVMe/TCP-TLS transport connection between the host and the NVMe subsystem. A valid value for property configured_psk is required.
This property defaults to none unless a value is supplied for configured_psk in which case it defaults to configured.
hosts
_links
_links
dh_hmac_chap
dh_hmac_chap
nqn
string
The NVMe qualified name (NQN) used to identify the NVMe storage target.
priority
string
The host priority setting allocates appropriate NVMe I/O queues (count and depth) for the host to submit I/O commands. Absence of this property in GET implies user configured values of I/O queue count and I/O queue depth are being used.
tls
tls
default
The default I/O queue parameters inherited by NVMe hosts in the NVMe subsystem.
count
integer
The number of host I/O queue pairs.
depth
integer
The host I/O queue depth.
io_queue
The properties of the submission queue used to submit I/O commands for execution by the NVMe controller.
default
default
namespace
An NVMe namespace mapped to the NVMe subsystem.
_links
_links
name
string
The name of the NVMe namespace.
uuid
string
The unique identifier of the NVMe namespace.
subsystem_maps
_links
_links
anagrpid
string
The Asymmetric Namespace Access Group ID (ANAGRPID) of the NVMe namespace.
The format for an ANAGRPIP is 8 hexadecimal digits (zero-filled) followed by a lower case "h".
namespace
namespace
nsid
string
The NVMe namespace identifier. This is an identifier used by an NVMe controller to provide access to the NVMe namespace.
The format for an NVMe namespace identifier is 8 hexadecimal digits (zero-filled) followed by a lower case "h".
svm
_links
_links
name
string
uuid
string
nvme_subsystem
An NVMe subsystem maintains configuration state and namespace access control for a set of NVMe-connected hosts.
_links
_links
comment
string
A configurable comment for the NVMe subsystem. Optional in POST and PATCH.
delete_on_unmap
boolean
An option that causes the subsystem to be deleted when the last subsystem map associated with it is deleted. Optional in POST and PATCH. This property defaults to false when the subsystem is created.
hosts
array[hosts]
The NVMe hosts configured for access to the NVMe subsystem. Optional in POST.
io_queue
io_queue
name
string
The name of the NVMe subsystem. Once created, an NVMe subsystem cannot be renamed. Required in POST.
os_type
string
The host operating system of the NVMe subsystem's hosts. Required in POST.
serial_number
string
The serial number of the NVMe subsystem.
subsystem_maps
array[subsystem_maps]
The NVMe namespaces mapped to the NVMe subsystem.
There is an added computational cost to retrieving property values for subsystem_maps. They are not populated for a GET request unless explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
svm
svm
target_nqn
string
uuid
string
The unique identifier of the NVMe subsystem.
vendor_uuids
array[string]
Vendor-specific identifiers (UUIDs) optionally assigned to an NVMe subsystem when the subsystem is created. The identifiers are used to enable vendor-specific NVMe protocol features. The identifiers are provided by a host application vendor and shared with NetApp prior to a joint product release. Creating an NVMe subsystem with an unknown or non-specific identifier will have no effect on the NVMe subsystem. Refer to the ONTAP SAN Administration Guide for a list of the supported vendor-specific identifiers. After a subsystem is created, the vendor-specific identifiers cannot be changed or removed. Optional in POST.
  • readCreate: 1
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
