REST API reference
Retrieve NVMe subsystems
Retrieves NVMe subsystems to access their current configurations and status within your storage environment.
HTTP method and endpoint
GET /protocols/nvme/subsystems
Introduced in
ONTAP 9.6
  • vserver nvme subsystem host show
  • vserver nvme subsystem map show
  • vserver nvme subsystem show
serial_number
string
query
False
Filter by serial_number
name
string
query
False
Filter by name
hosts.nqn
string
query
False
Filter by hosts.nqn
subsystem_maps.nsid
string
query
False
Filter by subsystem_maps.nsid
subsystem_maps.anagrpid
string
query
False
Filter by subsystem_maps.anagrpid
subsystem_maps.namespace.name
string
query
False
Filter by subsystem_maps.namespace.name
subsystem_maps.namespace.uuid
string
query
False
Filter by subsystem_maps.namespace.uuid
comment
string
query
False
Filter by comment
vendor_uuids
string
query
False
Filter by vendor_uuids
  • Introduced in: 9.9
delete_on_unmap
boolean
query
False
Filter by delete_on_unmap
  • Introduced in: 9.7
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
uuid
string
query
False
Filter by uuid
target_nqn
string
query
False
Filter by target_nqn
io_queue.default.count
integer
query
False
Filter by io_queue.default.count
io_queue.default.depth
integer
query
False
Filter by io_queue.default.depth
os_type
string
query
False
Filter by os_type
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records.
records
array[nvme_subsystem]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "comment": "string",
      "hosts": [
          "nqn": "nqn.1992-01.example.com:string"
      "io_queue": {
        "default": {
          "count": "4",
          "depth": "16"
      "name": "subsystem1",
      "os_type": "string",
      "serial_number": "wCVsgFMiuMhVAAAAAAAB",
      "subsystem_maps": [
          "anagrpid": "00103050h",
          "namespace": {
            "name": "/vol/vol1/namespace1",
          "nsid": "00000001h"
      "svm": {
        "name": "svm1",
      "target_nqn": "nqn.1992-01.example.com:string",
      "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
      "vendor_uuids": [
        "1447f0f4-42e5-0dfc-871a-dc9b3f92d8f8"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
hosts
nqn
string
The NVMe qualified name (NQN) used to identify the NVMe storage target.
default
The default I/O queue parameters inherited by NVMe hosts in the NVMe subsystem.
count
integer
The number of host I/O queue pairs.
depth
integer
The host I/O queue depth.
io_queue
The properties of the submission queue used to submit I/O commands for execution by the NVMe controller.
default
default
namespace
An NVMe namespace mapped to the NVMe subsystem.
_links
_links
name
string
The name of the NVMe namespace.
uuid
string
The unique identifier of the NVMe namespace.
subsystem_maps
_links
_links
anagrpid
string
The Asymmetric Namespace Access Group ID (ANAGRPID) of the NVMe namespace.
The format for an ANAGRPIP is 8 hexadecimal digits (zero-filled) followed by a lower case "h".
namespace
namespace
nsid
string
The NVMe namespace identifier. This is an identifier used by an NVMe controller to provide access to the NVMe namespace.
The format for an NVMe namespace identifier is 8 hexadecimal digits (zero-filled) followed by a lower case "h".
svm
_links
_links
name
string
The name of the SVM.
uuid
string
nvme_subsystem
An NVMe subsystem maintains configuration state and namespace access control for a set of NVMe-connected hosts.
_links
_links
comment
string
A configurable comment for the NVMe subsystem. Optional in POST and PATCH.
delete_on_unmap
boolean
An option that causes the subsystem to be deleted when the last subsystem map associated with it is deleted. This property defaults to false when the subsystem is created.
hosts
array[hosts]
The NVMe hosts configured for access to the NVMe subsystem. Optional in POST.
io_queue
io_queue
name
string
The name of the NVMe subsystem. Once created, an NVMe subsystem cannot be renamed. Required in POST.
os_type
string
The host operating system of the NVMe subsystem's hosts. Required in POST.
serial_number
string
The serial number of the NVMe subsystem.
subsystem_maps
array[subsystem_maps]
The NVMe namespaces mapped to the NVMe subsystem.
There is an added cost to retrieving property values for subsystem_maps. They are not populated for either a collection GET or an instance GET unless explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
svm
svm
target_nqn
string
uuid
string
The unique identifier of the NVMe subsystem.
vendor_uuids
array[string]
Vendor-specific identifiers (UUIDs) optionally assigned to an NVMe subsystem when the subsystem is created. The identifiers are used to enable vendor-specific NVMe protocol features. The identifiers are provided by a host application vendor and shared with NetApp prior to a joint product release. Creating an NVMe subsystem with an unknown or non-specific identifier will have no effect on the NVMe subsystem. Refer to the ONTAP SAN Administration Guide for a list of the supported vendor-specific identifiers. After a subsystem is created, the vendor-specific identifiers cannot be changed or removed. Optional in POST.
  • readCreate: 1
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
