REST API reference
Retrieve a Vscan On-Access policy
Accesses the Vscan On-Access policy to review the current antivirus scanning configuration for files accessed within the ONTAP environment. Use this information to ensure your data is protected according to your organization's security requirements.
HTTP method and endpoint
GET /protocols/vscan/{svm.uuid}/on-access-policies
Introduced in
ONTAP 9.6
Usage notes
Retrieves the Vscan On-Access policy.
  • vserver vscan on-access-policy show
  • vserver vscan on-access-policy file-ext-to-include show
  • vserver vscan on-access-policy file-ext-to-exclude show
  • vserver vscan on-access-policy paths-to-exclude show
name
string
query
False
Filter by name
scope.only_execute_access
boolean
query
False
Filter by scope.only_execute_access
scope.exclude_paths
string
query
False
Filter by scope.exclude_paths
scope.max_file_size
integer
query
False
Filter by scope.max_file_size
scope.scan_without_extension
boolean
query
False
Filter by scope.scan_without_extension
scope.include_extensions
string
query
False
Filter by scope.include_extensions
scope.exclude_extensions
string
query
False
Filter by scope.exclude_extensions
scope.scan_readonly_volumes
boolean
query
False
Filter by scope.scan_readonly_volumes
mandatory
boolean
query
False
Filter by mandatory
enabled
boolean
query
False
Filter by enabled
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[vscan_on_access]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "name": "on-access-test",
      "scope": {
        "exclude_extensions": [
          "mp*",
          "txt"
        "exclude_paths": [
          "\\dir1\\dir2\\name",
          "\\vol\\a b",
          "\\vol\\a,b\\"
        "include_extensions": [
          "mp*",
          "txt"
        "max_file_size": 2147483648
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
scope
exclude_extensions
array[string]
List of file extensions for which scanning is not performed.
exclude_paths
array[string]
List of file paths for which scanning must not be performed.
include_extensions
array[string]
List of file extensions to be scanned.
max_file_size
integer
Maximum file size, in bytes, allowed for scanning.
only_execute_access
boolean
Scan only files opened with execute-access.
boolean
Specifies whether or not read-only volume can be scanned.
boolean
Specifies whether or not files without any extension can be scanned.
vscan_on_access
An On-Access policy that defines the scope of an On-Access scan. Use On-Access scanning to check for viruses when clients open, read, rename, or close files over CIFS. By default, ONTAP creates an On-Access policy named "default_CIFS" and enables it for all the SVMs in a cluster.
enabled
boolean
Status of the On-Access Vscan policy
mandatory
boolean
Specifies if scanning is mandatory. File access is denied if there are no external virus-scanning servers available for virus scanning.
name
string
On-Access policy ame
scope
scope
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
