REST API reference
Retrieve a Vscan On-Access policy
GET /protocols/vscan/{svm.uuid}/on-access-policies
Introduced In: 9.6
Retrieves the Vscan On-Access policy.
  • vserver vscan on-access-policy show
  • vserver vscan on-access-policy file-ext-to-include show
  • vserver vscan on-access-policy file-ext-to-exclude show
  • vserver vscan on-access-policy paths-to-exclude show
protocol
string
query
False
Filter by protocol
  • Introduced in: 9.18
mandatory
boolean
query
False
Filter by mandatory
enabled
boolean
query
False
Filter by enabled
scope.scan_readonly_volumes
boolean
query
False
Filter by scope.scan_readonly_volumes
scope.exclude_extensions
string
query
False
Filter by scope.exclude_extensions
scope.max_file_size
integer
query
False
Filter by scope.max_file_size
  • Max value: 1099511627776
  • Min value: 1024
scope.only_execute_access
boolean
query
False
Filter by scope.only_execute_access
scope.include_extensions
string
query
False
Filter by scope.include_extensions
scope.exclude_paths
string
query
False
Filter by scope.exclude_paths
  • maxLength: 255
  • minLength: 1
scope.scan_without_extension
boolean
query
False
Filter by scope.scan_without_extension
owner
string
query
False
Filter by owner
name
string
query
False
Filter by name
  • maxLength: 256
  • minLength: 1
svm.name
string
query
False
Filter by svm.name
  • Introduced in: 9.16
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[vscan_on_access]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "name": "on-access-test",
      "owner": "string",
      "protocol": "string",
      "scope": {
        "exclude_extensions": [
          "mp*",
          "txt"
        "exclude_paths": [
          "\\dir1\\dir2\\name",
          "\\vol\\a b",
          "\\vol\\a,b\\"
        "include_extensions": [
          "mp*",
          "txt"
        "max_file_size": 2147483648
      "svm": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
scope
exclude_extensions
array[string]
List of file extensions for which scanning is not performed.
exclude_paths
array[string]
List of file paths for which scanning must not be performed.
include_extensions
array[string]
List of file extensions to be scanned.
max_file_size
integer
Maximum file size, in bytes, allowed for scanning.
only_execute_access
boolean
Scan only files opened with execute-access.
boolean
Specifies whether or not read-only volume can be scanned.
boolean
Specifies whether or not files without any extension can be scanned.
self
svm
_links
_links
name
string
uuid
string
vscan_on_access
An On-Access policy that defines the scope of an On-Access scan. Use On-Access scanning to check for viruses when clients open, read, rename, or close files over CIFS. By default, ONTAP creates an On-Access policy named "default_CIFS" and enables it for all the SVMs in a cluster.
enabled
boolean
Status of the On-Access Vscan policy
mandatory
boolean
Specifies if scanning is mandatory. File access is denied if there are no external virus-scanning servers available for virus scanning.
name
string
owner
string
Specifies the on-access policy owner.
protocol
string
Specifies the file access protocol for the on-access policy. The following lists the possible protocols. CIFS - SMB protocol
scope
scope
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
