Retrieve a Vscan On-Access policy
Retrieves details of a Vscan On-Access policy to understand its current configuration and settings.
HTTP method and endpoint
GET /protocols/vscan/{svm.uuid}/on-access-policies
Introduced in
ONTAP 9.6
Usage notes
Retrieves the Vscan On-Access policy.
Related ONTAP commands
vserver vscan on-access-policy show -
vserver vscan on-access-policy file-ext-to-include show -
vserver vscan on-access-policy file-ext-to-exclude show -
vserver vscan on-access-policy paths-to-exclude show
enabled |
boolean |
query |
False |
Filter by enabled |
scope.exclude_paths |
string |
query |
False |
Filter by scope.exclude_paths |
scope.max_file_size |
integer |
query |
False |
Filter by scope.max_file_size |
scope.only_execute_access |
boolean |
query |
False |
Filter by scope.only_execute_access |
scope.include_extensions |
string |
query |
False |
Filter by scope.include_extensions |
scope.scan_readonly_volumes |
boolean |
query |
False |
Filter by scope.scan_readonly_volumes |
scope.exclude_extensions |
string |
query |
False |
Filter by scope.exclude_extensions |
scope.scan_without_extension |
boolean |
query |
False |
Filter by scope.scan_without_extension |
mandatory |
boolean |
query |
False |
Filter by mandatory |
name |
string |
query |
False |
Filter by name |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[vscan_on_access] |
"next": {
"href": "/api/resourcelink"
"records": [
"name": "on-access-test",
"scope": {
"exclude_extensions": [
"mp*",
"txt"
"exclude_paths": [
"\\dir1\\dir2\\name",
"\\vol\\a b",
"\\vol\\a,b\\"
"include_extensions": [
"mp*",
"txt"
"max_file_size": "2147483648"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
scope
array[string] |
List of file extensions for which scanning is not performed. |
exclude_paths |
array[string] |
List of file paths for which scanning must not be performed. |
array[string] |
List of file extensions to be scanned. |
max_file_size |
integer |
Maximum file size, in bytes, allowed for scanning. |
boolean |
Scan only files opened with execute-access. |
boolean |
Specifies whether or not read-only volume can be scanned. |
boolean |
Specifies whether or not files without any extension can be scanned. |
vscan_on_access
An On-Access policy that defines the scope of an On-Access scan. Use On-Access scanning to check for viruses when clients open, read, rename, or close files over CIFS. By default, ONTAP creates an On-Access policy named "default_CIFS" and enables it for all the SVMs in a cluster.
enabled |
boolean |
Status of the On-Access Vscan policy |
mandatory |
boolean |
Specifies if scanning is mandatory. File access is denied if there are no external virus-scanning servers available for virus scanning. |
name |
string |
On-Access policy ame |
scope |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
