REST API reference
Retrieve the Vscan scanner-pool configuration for an SVM
Accesses the configuration details for a specified Vscan scanner-pool within an SVM. This action helps you understand the current settings and manage the scanner-pool effectively.
HTTP method and endpoint
GET /protocols/vscan/{svm.uuid}/scanner-pools/{name}
Introduced in
ONTAP 9.6
Usage notes
Retrieves the configuration of a specified scanner-pool of an SVM.
  • vserver vscan scanner-pool show
  • vserver vscan scanner-pool privileged-users show
  • vserver vscan scanner-pool servers show
name
string
path
True
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
cluster
cluster_reference
name
string
Specifies the name of the scanner pool. Scanner pool name can be up to 256 characters long and is a string that can only contain any combination of ASCII-range alphanumeric characters a-z, A-Z, 0-9), "_", "-" and ".".
privileged_users
array[string]
Specifies a list of privileged users. A valid form of privileged user-name is "domain-name\user-name". Privileged user-names are stored and treated as case-insensitive strings. Virus scanners must use one of the registered privileged users for connecting to clustered Data ONTAP for exchanging virus-scanning protocol messages and to access file for scanning, remedying and quarantining operations.
  • example: ["cifs\u1", "cifs\u2"]
  • Introduced in: 9.6
role
string
Specifies the role of the scanner pool. The possible values are:
  • primary - Always active.
  • secondary - Active only when none of the primary external virus-scanning servers are connected.
  • idle - Always inactive.
servers
array[string]
Specifies a list of IP addresses or FQDN for each Vscan server host names which are allowed to connect to clustered ONTAP.
  • example: ["1.1.1.1", "10.72.204.27", "vmwin204-27.fsct.nb"]
svm
svm
  "cluster": {
        "href": "/api/resourcelink"
    "name": "cluster1",
  "name": "scanner-1",
  "privileged_users": [
    "cifs\\u1",
    "cifs\\u2"
  "role": "string",
  "servers": [
    "1.1.1.1",
    "10.72.204.27",
  "svm": {
    "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
cluster_reference
_links
_links
name
string
uuid
string
svm
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
