Retrieve the Vscan scanner-pool configuration for an SVM
GET /protocols/vscan/{svm.uuid}/scanner-pools/{name}
Retrieves the configuration of a specified scanner-pool of an SVM.
Related ONTAP commands
vserver vscan scanner-pool show -
vserver vscan scanner-pool privileged-users show -
vserver vscan scanner-pool servers show -
vserver vscan scanner-pool show-active
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
name |
string |
path |
True |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
cluster |
name |
string |
Specifies the name of the scanner pool. Scanner pool name can be up to 256 characters long and is a string that can only contain any combination of ASCII-range alphanumeric characters a-z, A-Z, 0-9), "_", "-" and ".". |
privileged_users |
array[string] |
Specifies a list of privileged users. A valid form of privileged user-name is "domain-name\user-name". Privileged user-names are stored and treated as case-insensitive strings. Virus scanners must use one of the registered privileged users for connecting to clustered Data ONTAP for exchanging virus-scanning protocol messages and to access file for scanning, remedying and quarantining operations.
role |
string |
Specifies the role of the scanner pool. The possible values are:
servers |
array[string] |
Specifies a list of IP addresses or FQDN for each Vscan server host names which are allowed to connect to clustered ONTAP.
"cluster": {
"href": "/api/resourcelink"
"name": "cluster1",
"name": "scanner-1",
"privileged_users": [
"cifs\\u1",
"cifs\\u2"
"role": "string",
"servers": [
"1.1.1.1",
"10.72.204.27",
"vmwin204-27.fsct.nb"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
cluster_reference
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
