REST API reference
Retrieve information on the suspects generated by anti-ransomware analytics
Retrieves information about suspects identified by anti-ransomware analytics to understand potential security threats within your system.
HTTP method and endpoint
GET /security/anti-ransomware/suspects
Introduced in
ONTAP 9.10
Usage notes
Retrieves information on the suspects generated by the anti-ransomware analytics.
  • security anti-ransomware volume attack generate-report
file.suspect_time
string
query
False
Filter by file.suspect_time
file.path
string
query
False
Filter by file.path
file.format
string
query
False
Filter by file.format
file.name
string
query
False
Filter by file.name
volume.uuid
string
query
False
Filter by volume.uuid
volume.name
string
query
False
Filter by volume.name
is_false_positive
boolean
query
False
Filter by is_false_positive
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[anti_ransomware_suspect]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "file": {
        "format": "pdf",
        "name": "test_file",
        "path": "d1/d2/d3",
        "suspect_time": "2021-05-12T11:00:16-04:00"
      "volume": {
        "name": "string",
        "uuid": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
file
format
string
File format of the suspected file.
name
string
Name of the suspected file.
path
string
Path of the suspected file.
suspect_time
string
Time when the file was detected as a potential suspect in date-time format.
volume
name
string
uuid
string
File suspected to be potentially attacked by ransomware.
_links
_links
file
file
is_false_positive
boolean
Specifies whether the suspected ransomware activity is a false positive or not. This parameter is only used when making a DELETE call.
volume
volume
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
