REST API reference
Retrieve information on the suspects generated by anti-ransomware analytics
Views details about the suspects identified by anti-ransomware analytics, which helps you assess potential security threats.
HTTP method and endpoint
GET /security/anti-ransomware/suspects
Introduced in
ONTAP 9.10
Usage notes
Retrieves information on the suspects generated by the anti-ransomware analytics.
  • security anti-ransomware volume attack generate-report
volume.name
string
query
False
Filter by volume.name
volume.uuid
string
query
False
Filter by volume.uuid
file.format
string
query
False
Filter by file.format
file.path
string
query
False
Filter by file.path
file.suspect_time
string
query
False
Filter by file.suspect_time
file.name
string
query
False
Filter by file.name
file.reason
string
query
False
Filter by file.reason
  • Introduced in: 9.11
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[anti_ransomware_suspect]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "file": {
        "format": "pdf",
        "name": "test_file",
        "path": "d1/d2/d3",
        "reason": "High Entropy",
        "suspect_time": "2021-05-12 11:00:16 -0400"
      "volume": {
        "name": "volume1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
file
format
string
File format of the suspected file.
name
string
Name of the suspected file.
path
string
Path of the suspected file.
reason
string
Reason behind this file being suspected
suspect_time
string
Time when the file was detected as a potential suspect in date-time format.
volume
_links
_links
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
File suspected to be potentially attacked by ransomware.
_links
_links
file
file
volume
volume
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
