Retrieve information on the suspects generated by anti-ransomware analytics
Retrieves information on suspects identified by anti-ransomware analytics, which helps you analyze potential threats and take appropriate security actions.
HTTP method and endpoint
GET /security/anti-ransomware/suspects
Introduced in
ONTAP 9.10
Usage notes
Retrieves information on the suspects generated by the anti-ransomware analytics.
Related ONTAP commands
security anti-ransomware volume attack generate-report
file.reason |
string |
query |
False |
Filter by file.reason
file.suspect_time |
string |
query |
False |
Filter by file.suspect_time |
file.path |
string |
query |
False |
Filter by file.path |
file.name |
string |
query |
False |
Filter by file.name |
file.format |
string |
query |
False |
Filter by file.format |
volume.uuid |
string |
query |
False |
Filter by volume.uuid |
volume.name |
string |
query |
False |
Filter by volume.name |
is_false_positive |
boolean |
query |
False |
Filter by is_false_positive |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[anti_ransomware_suspect] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"file": {
"format": "pdf",
"name": "test_file",
"path": "d1/d2/d3",
"reason": "High Entropy",
"suspect_time": "2021-05-12T11:00:16-04:00"
"volume": {
"name": "volume1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
file
format |
string |
File format of the suspected file. |
name |
string |
Name of the suspected file. |
path |
string |
Path of the suspected file. |
reason |
string |
Reason behind this file bieng suspected |
suspect_time |
string |
Time when the file was detected as a potential suspect in date-time format. |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
File suspected to be potentially attacked by ransomware.
_links |
file |
is_false_positive |
boolean |
Specifies whether the suspected ransomware activity is a false positive or not. This parameter is only used when making a DELETE call. |
volume |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
