REST API reference
Retrieve the administrative audit settings for GET requests
Retrieves the administrative audit settings to review configurations related to GET request activities. This helps you ensure compliance and maintain a secure audit trail within your system.
HTTP method and endpoint
GET /security/audit
Introduced in
ONTAP 9.6
Usage notes
Retrieves administrative audit settings for GET requests.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
cli
boolean
Enable auditing of CLI GET Operations. Valid in PATCH
http
boolean
Enable auditing of HTTP GET Operations. Valid in PATCH
ontapi
boolean
Enable auditing of ONTAP API GET operations. Valid in PATCH
  • Introduced in: 9.6
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
