REST API reference
Retrieve administrative audit settings for GET requests
Retrieves administrative audit settings to review and manage how GET requests are logged for auditing purposes.
HTTP method and endpoint
GET /security/audit
Introduced in
ONTAP 9.6
Usage notes
Retrieves administrative audit settings for GET requests.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
desc] direction. Default direction is 'asc' for ascending.
fields
array[string]
query
False
Status: 200, Ok
Name Type Description
cli
boolean
Enable auditing of CLI GET Operations. Valid in PATCH
http
boolean
Enable auditing of HTTP GET Operations. Valid in PATCH
ontapi
boolean
Enable auditing of ONTAP API GET operations. Valid in PATCH
  • Introduced in: 9.6
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
