Retrieve administrative audit settings for GET requests
Retrieves the administrative audit settings to review configurations related to GET request activities. This helps you ensure compliance and maintain a secure audit trail within your system.
HTTP method and endpoint
GET /security/audit
Introduced in
ONTAP 9.6
Usage notes
Retrieves administrative audit settings for GET requests.
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
cli |
boolean |
Enable auditing of CLI GET Operations. Valid in PATCH |
http |
boolean |
Enable auditing of HTTP GET Operations. Valid in PATCH |
ontapi |
boolean |
Enable auditing of ONTAP API GET operations. Valid in PATCH
"href": "/api/resourcelink"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
