REST API reference
Retrieve public keys configured for user accounts
Retrieves public keys configured for user accounts to verify authentication and enhance security measures within the system.
HTTP method and endpoint
GET /security/authentication/publickeys
Introduced in
ONTAP 9.7
  • security login publickey show
scope
string
query
False
Filter by scope
comment
string
query
False
Filter by comment
obfuscated_fingerprint
string
query
False
Filter by obfuscated_fingerprint
account.name
string
query
False
Filter by account.name
index
integer
query
False
Filter by index
owner.uuid
string
query
False
Filter by owner.uuid
owner.name
string
query
False
Filter by owner.name
sha_fingerprint
string
query
False
Filter by sha_fingerprint
public_key
string
query
False
Filter by public_key
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[publickey]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "account": {
        "name": "joe.smith"
      "comment": "string",
      "obfuscated_fingerprint": "string",
      "owner": {
        "name": "svm1",
      "public_key": "string",
      "scope": "string",
      "sha_fingerprint": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
account_reference
_links
_links
name
string
User account
owner
Owner name and UUID that uniquely identifies the public key.
_links
_links
name
string
The name of the SVM.
uuid
string
publickey
The public key for the user account (to access SSH).
_links
_links
account
account_reference
comment
string
Optional comment for the public key.
index
integer
Index number for the public key (where there are multiple keys for the same account).
string
The obfuscated fingerprint for the public key (READONLY).
owner
owner
public_key
string
The public key
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
sha_fingerprint
string
The SHA fingerprint for the public key (READONLY).
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
