Retrieve public keys configured for user accounts
Accesses the list of public keys that are configured for user accounts. This can be useful for managing authentication settings or verifying which keys are in use.
HTTP method and endpoint
GET /security/authentication/publickeys
Introduced in
ONTAP 9.7
Usage notes
Retrieves the public keys configured for user accounts.
Related ONTAP commands
security login publickey show
certificate_revoked |
string |
query |
False |
Filter by certificate_revoked
index |
integer |
query |
False |
Filter by index
certificate_expired |
string |
query |
False |
Filter by certificate_expired
certificate_details |
string |
query |
False |
Filter by certificate_details
obfuscated_fingerprint |
string |
query |
False |
Filter by obfuscated_fingerprint |
sha_fingerprint |
string |
query |
False |
Filter by sha_fingerprint |
certificate |
string |
query |
False |
owner.uuid |
string |
query |
False |
Filter by owner.uuid |
owner.name |
string |
query |
False |
Filter by owner.name |
comment |
string |
query |
False |
Filter by comment |
scope |
string |
query |
False |
Filter by scope |
public_key |
string |
query |
False |
Filter by public_key |
account.name |
string |
query |
False |
Filter by account.name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[publickey] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"account": {
"name": "joe.smith"
"certificate": "string",
"certificate_details": "string",
"certificate_expired": "string",
"certificate_revoked": "string",
"comment": "string",
"obfuscated_fingerprint": "string",
"owner": {
"name": "svm1",
"public_key": "string",
"scope": "string",
"sha_fingerprint": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
account_reference
_links |
name |
string |
User account |
owner
Owner name and UUID that uniquely identifies the public key.
_links |
name |
string |
uuid |
string |
publickey
The public key for the user account (to access SSH).
_links |
account |
certificate |
string |
Optional certificate for the public key. |
string |
The details present in the certificate (READONLY). |
string |
The expiration details of the certificate (READONLY). |
string |
The revocation details of the certificate (READONLY). |
comment |
string |
Optional comment for the public key. |
index |
integer |
Index number for the public key (where there are multiple keys for the same account). |
string |
The obfuscated fingerprint for the public key (READONLY). |
owner |
Owner name and UUID that uniquely identifies the public key. |
public_key |
string |
The public key |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
sha_fingerprint |
string |
The SHA fingerprint for the public key (READONLY). |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
