REST API reference
Retrieve public keys configured for user accounts
Retrieves public keys that are configured for user accounts, which helps you manage secure access configurations within your system.
HTTP method and endpoint
GET /security/authentication/publickeys
Introduced in
ONTAP 9.7
Usage notes
Retrieves the public keys configured for user accounts.
  • security login publickey show
certificate_expired
string
query
False
Filter by certificate_expired
  • Introduced in: 9.13
obfuscated_fingerprint
string
query
False
Filter by obfuscated_fingerprint
account.name
string
query
False
Filter by account.name
owner.name
string
query
False
Filter by owner.name
owner.uuid
string
query
False
Filter by owner.uuid
certificate
string
query
False
certificate_revoked
string
query
False
Filter by certificate_revoked
public_key
string
query
False
Filter by public_key
certificate_details
string
query
False
Filter by certificate_details
sha_fingerprint
string
query
False
Filter by sha_fingerprint
index
integer
query
False
Filter by index
  • Max value: 99
  • Min value: 0
scope
string
query
False
Filter by scope
comment
string
query
False
Filter by comment
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[publickey]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "account": {
        "name": "joe.smith"
      "certificate": "string",
      "certificate_details": "string",
      "certificate_expired": "string",
      "certificate_revoked": "string",
      "comment": "string",
      "obfuscated_fingerprint": "string",
      "owner": {
        "name": "svm1",
      "public_key": "string",
      "scope": "string",
      "sha_fingerprint": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
account_reference
_links
_links
name
string
User account
owner
Owner name and UUID that uniquely identifies the public key.
_links
_links
name
string
uuid
string
publickey
The public key for the user account (to access SSH).
_links
_links
account
account_reference
certificate
string
Optional certificate for the public key.
certificate_details
string
The details present in the certificate (READONLY).
certificate_expired
string
The expiration details of the certificate (READONLY).
certificate_revoked
string
The revocation details of the certificate (READONLY).
comment
string
Optional comment for the public key.
index
integer
Index number for the public key (where there are multiple keys for the same account).
string
The obfuscated fingerprint for the public key (READONLY).
owner
owner
public_key
string
The public key
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
sha_fingerprint
string
The SHA fingerprint for the public key (READONLY).
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
