Retrieve public keys configured for user accounts
GET /security/authentication/publickeys
Introduced In: 9.7
Retrieves the public keys configured for user accounts.
Related ONTAP commands
security login publickey show
scope |
string |
query |
False |
Filter by scope |
comment |
string |
query |
False |
Filter by comment |
owner.uuid |
string |
query |
False |
Filter by owner.uuid |
owner.name |
string |
query |
False |
Filter by owner.name |
public_key |
string |
query |
False |
Filter by public_key |
account.name |
string |
query |
False |
Filter by account.name |
sha_fingerprint |
string |
query |
False |
Filter by sha_fingerprint |
obfuscated_fingerprint |
string |
query |
False |
Filter by obfuscated_fingerprint |
index |
integer |
query |
False |
Filter by index |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[publickey] |
"next": {
"href": "/api/resourcelink"
"records": [
"account": {
"name": "joe.smith"
"comment": "string",
"obfuscated_fingerprint": "string",
"owner": {
"name": "svm1",
"public_key": "string",
"scope": "string",
"sha_fingerprint": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
account_reference
_links |
name |
string |
User account |
owner
Owner name and UUID that uniquely identifies the public key.
_links |
name |
string |
The name of the SVM. |
uuid |
string |
publickey
The public key for the user account (to access SSH).
_links |
account |
comment |
string |
Optional comment for the public key. |
index |
integer |
Index number for the public key (where there are multiple keys for the same account). |
string |
The obfuscated fingerprint for the public key (READONLY). |
owner |
Owner name and UUID that uniquely identifies the public key. |
public_key |
string |
The public key |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
sha_fingerprint |
string |
The SHA fingerprint for the public key (READONLY). |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
