Retrieve the access level for a REST API path or command/command directory path for a role
Retrieves the access level for a specific REST API path or command directory path associated with a role. This helps you understand the privilege level assigned to different API paths for the role in question.
HTTP method and endpoint
GET /security/roles/{owner.uuid}/{name}/privileges/{path}
Introduced in
ONTAP 9.6
Usage notes
Retrieves the privilege level for a REST API path for the specified role. The REST API path can be a resource-qualified endpoint. Currently, the only supported resource-qualified endpoints are /api/storage/volumes/{volume.uuid}/snapshots and /api/storage/volumes//snapshots. "" is a wildcard character denoting "all" volumes.
Related ONTAP commands
security login rest-role show
owner.uuid |
string |
path |
True |
Role owner UUID |
name |
string |
path |
True |
Role name |
path |
string |
path |
True |
REST API path |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
access |
string |
Access level for the REST endpoint. |
path |
string |
REST URI/endpoint |
"href": "/api/resourcelink"
"access": "readonly",
"path": "/api/storage/volumes"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
