REST API reference
Retrieve the access level for a REST API path or command/command directory path for a role
GET /security/roles/{owner.uuid}/{name}/privileges/{path}
Introduced In: 9.6
Retrieves the access level for a REST API path or command/command directory path for the specified role. Optionally retrieves the query, if 'path' refers to a command/command directory path. The REST API path can be a resource-qualified endpoint. Currently, the only supported resource-qualified endpoints are the following:
Snapshots APIs
– /api/storage/volumes/{volume.uuid}/snapshots
File System Analytics APIs
– /api/storage/volumes/{volume.uuid}/files
– /api/storage/volumes/{volume.uuid}/top-metrics/clients
– /api/storage/volumes/{volume.uuid}/top-metrics/directories
– /api/storage/volumes/{volume.uuid}/top-metrics/files
– /api/storage/volumes/{volume.uuid}/top-metrics/users
– /api/svm/svms/{svm.uuid}/top-metrics/clients
– /api/svm/svms/{svm.uuid}/top-metrics/directories
– /api/svm/svms/{svm.uuid}/top-metrics/files
– /api/svm/svms/{svm.uuid}/top-metrics/users
ONTAP S3 APIs
– /api/protocols/s3/services/{svm.uuid}/users
In the APIs above, and in the context of REST roles, the wildcard character * can be used in place of {volume.uuid} or {svm.uuid} to represent all volumes or all SVMs, depending on whether the REST endpoint references volumes or SVMs. The {volume.uuid} corresponds to the -instance-uuid field in the output of the "volume show" command at the diagnostic privilege level. It can also be retrieved through the REST endpoint /api/storage/volumes.
  • security login rest-role show
  • security login role show
owner.uuid
string
path
True
Role owner UUID
name
string
path
True
Role name
path
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
access
string
Access level for the REST endpoint or command/command directory path. If it denotes the access level for a command/command directory path, the only supported enum values are 'none','readonly' and 'all'.
path
string
Either of REST URI/endpoint OR command/command directory path.
query
string
Optional attribute that can be specified only if the "path" attribute refers to a command/command directory path. The privilege tuple implicitly defines a set of objects the role can or cannot access at the specified access level. The query further reduces this set of objects to a subset of objects that the role is allowed to access. The query attribute must be applicable to the command/command directory specified by the "path" attribute. It is defined using one or more parameters of the command/command directory path specified by the "path" attribute.
      "href": "/api/resourcelink"
  "access": "all",
  "path": "volume move start",
  "query": "-vserver vs1|vs2|vs3 -destination-aggregate aggr1|aggr2"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
