REST API reference
Retrieve the access level for a REST API path or command/command directory path for a role
Retrieves access level information for a specific REST API path or command directory path associated with a role. This can help you manage and verify role-based permissions in your system.
HTTP method and endpoint
GET /security/roles/{owner.uuid}/{name}/privileges/{path}
Introduced in
ONTAP 9.6
Usage notes
Retrieves the access level for a REST API path or command/command directory path for the specified role. Optionally retrieves the query, if 'path' refers to a command/command directory path. The REST API path can be a resource-qualified endpoint. Currently, the only supported resource-qualified endpoints are the following:
Snapshots APIs
– /api/storage/volumes/{volume.uuid}/snapshots
File System Analytics APIs
– /api/storage/volumes/{volume.uuid}/files
– /api/storage/volumes/{volume.uuid}/top-metrics/clients
– /api/storage/volumes/{volume.uuid}/top-metrics/directories
– /api/storage/volumes/{volume.uuid}/top-metrics/files
– /api/storage/volumes/{volume.uuid}/top-metrics/users
– /api/svm/svms/{svm.uuid}/top-metrics/clients
– /api/svm/svms/{svm.uuid}/top-metrics/directories
– /api/svm/svms/{svm.uuid}/top-metrics/files
– /api/svm/svms/{svm.uuid}/top-metrics/users
ONTAP S3 APIs
– /api/protocols/s3/services/{svm.uuid}/users
Artificial Intelligence Data Engine (AIDE) APIs
Data Compute Node (DCN) APIs
– /api/dcn/cluster/nodes/{node.uuid}/metrics
– /api/dcn/network/ports/{port.uuid}/metrics
Data-Engine APIs
– /api/data-engine/policies/{policy.uuid}/versions
– /api/data-engine/workspaces/{workspace.uuid}/acls
– /api/data-engine/workspaces/{workspace.uuid}/data-collections
– /api/data-engine/workspaces/{workspace.uuid}/data-collections/{datacollection.uuid}/acls
– /api/data-engine/workspaces/{workspace.uuid}/data-collections/{entity.uuid}/entities
– /api/data-engine/workspaces/{workspace.uuid}/data-collections/{datacollection.uuid}/search
– /api/data-engine/workspaces/{workspace.uuid}/data-collections/{datacollection.uuid}/versions
– /api/data-engine/workspaces/{workspace.uuid}/data-collections/{datacollection.uuid}/versions/{version.uuid}/diffs
– /api/data-engine/workspaces/{workspace.uuid}/data-sources
– /api/data-engine/workspaces/{workspace.uuid}/entities
– /api/data-engine/workspaces/{workspace.uuid}/entities/{entity.uuid}/custom-attributes
– /api/data-engine/workspaces/{workspace.uuid}/queries
– /api/data-engine/workspaces/{workspace.uuid}/queries/{query.uuid}/entities
– /api/data-engine/workspaces/{workspace.uuid}/versions
– /api/data-engine/workspaces/{workspace.uuid}/versions/{version.uuid}/diffs
When used in the context of data collection APIs, {version.uuid} refers to a data collection version. In the context of workspace APIs, it refers to a workspace version.
In the APIs above, and in the context of REST roles, the wildcard character * can be used in place of {volume.uuid} or {svm.uuid} to represent all volumes or all SVMs, depending on whether the REST endpoint references volumes or SVMs. The {volume.uuid} corresponds to the -instance-uuid field in the output of the "volume show" command at the diagnostic privilege level. It can also be retrieved through the REST endpoint /api/storage/volumes.
In the AIDE APIs described above, and in the context of REST roles, the wildcard character * can be used in place of variable components in the Uniform Resource Identifier (URI) path, such as {node.uuid}, {port.uuid}, {policy.uuid}, {workspace.uuid}, {datacollection.uuid}, {entity.uuid}, {version.uuid}, or {query.uuid}. The specific variable to be replaced depends on whether the REST endpoint references nodes, ports, policies, workspaces, data collections, entities, versions, or queries.
However, when using the wildcard character * in place of a variable component in a URI path, it must replace
all variable components in that path. Mixing wildcards and specific values for different variable components within the same URI path is not supported in REST roles. For example, a URI path such as /api/data-engine/workspaces/c6e1b325-4125-11f0-abb5-bc2411f6fd43/data-collections/*/search is not supported.
In summary, only the following two types of resource-qualified endpoints are supported in a REST role:
  • All variable components in the URI path are specific values. Example: /api/data-engine/workspaces/c6e1b325-4125-11f0-abb5-bc2411f6fd43/data-collections/b09b6d25-4126-11f0-abb5-bc2411f6fd43/search
  • All variable components in the URI path are wildcards. Example: /api/data-engine/workspaces//data-collections//search
AIDE APIs are supported only in cluster-scoped REST roles, not in SVM-scoped REST roles.
  • security login rest-role show
  • security login role show
owner.uuid
string
path
True
Role owner UUID
name
string
path
True
Role name
path
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
access
string
Access level for the REST endpoint or command/command directory path. If it denotes the access level for a command/command directory path, the only supported enum values are 'none','readonly' and 'all'.
path
string
Either of REST URI/endpoint OR command/command directory path.
query
string
Optional attribute that can be specified only if the "path" attribute refers to a command/command directory path. The privilege tuple implicitly defines a set of objects the role can or cannot access at the specified access level. The query further reduces this set of objects to a subset of objects that the role is allowed to access. The query attribute must be applicable to the command/command directory specified by the "path" attribute. It is defined using one or more parameters of the command/command directory path specified by the "path" attribute.
      "href": "/api/resourcelink"
  "access": "all",
  "path": "volume move start",
  "query": "-vserver vs1|vs2|vs3 -destination-aggregate aggr1|aggr2"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
