REST API reference
Retrieve a list of roles configured in the cluster
Retrieves the list of roles configured in the cluster to view the current access permissions assigned within your environment.
HTTP method and endpoint
GET /security/roles
Introduced in
ONTAP 9.6
  • security login rest-role show
Learn more
owner.uuid
string
query
False
Filter by owner.uuid
  • Introduced in: 9.7
owner.name
string
query
False
Filter by owner.name
name
string
query
False
Filter by name
scope
string
query
False
Filter by scope
privileges.path
string
query
False
Filter by privileges.path
privileges.access
string
query
False
Filter by privileges.access
builtin
boolean
query
False
Filter by builtin
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[role]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "name": "admin",
      "owner": {
        "name": "svm1",
      "privileges": [
          "access": "readonly",
          "path": "/api/storage/volumes"
      "scope": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
owner
Owner name and UUID that uniquely identifies the role.
_links
_links
name
string
The name of the SVM.
uuid
string
role_privilege
A tuple containing the REST endpoint and the access level assigned to that endpoint. The REST endpoint can be a resource-qualified endpoint. At present, the only supported resource-qualified endpoints are /api/storage/volumes/{volume.uuid}/snapshots and /api/storage/volumes//snapshots. "" is a wildcard character denoting "all" volumes.
_links
_links
access
string
Access level for the REST endpoint.
path
string
REST URI/endpoint
role
A named set of privileges that defines the rights an account has when it is assigned the role.
_links
_links
builtin
boolean
Indicates if this is a built-in (pre-defined) role which cannot be modified or deleted.
name
string
Role name
owner
owner
privileges
array[role_privilege]
The list of privileges that this role has been granted.
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
