Retrieve a list of roles configured in the cluster
Gathers information about the roles configured in your cluster, helping you understand the access permissions and security configurations currently in place.
HTTP method and endpoint
GET /security/roles
Introduced in
ONTAP 9.6
Usage notes
Retrieves a list of roles configured in the cluster.
Related ONTAP commands
security login rest-role show -
security login role show
Learn more
comment |
string |
query |
False |
Filter by comment
privileges.path |
string |
query |
False |
Filter by privileges.path
privileges.query |
string |
query |
False |
Filter by privileges.query
privileges.access |
string |
query |
False |
Filter by privileges.access
name |
string |
query |
False |
Filter by name
builtin |
boolean |
query |
False |
Filter by builtin
owner.uuid |
string |
query |
False |
Filter by owner.uuid
owner.name |
string |
query |
False |
Filter by owner.name
scope |
string |
query |
False |
Filter by scope
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[role] |
"next": {
"href": "/api/resourcelink"
"records": [
"comment": "string",
"name": "admin",
"owner": {
"name": "svm1",
"privileges": [
"access": "readonly",
"path": [
"/api/cluster/jobs",
"/api/storage/volumes",
"job schedule interval",
"volume move"
"query": [
"-days <1 -hours >12",
"-vserver vs1|vs2|vs3 -destination-aggregate aggr1|aggr2"
"scope": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
owner
Owner name and UUID that uniquely identifies the role.
_links |
name |
string |
The name of the SVM. |
uuid |
string |
role_privilege
A tuple containing a REST endpoint or a command/command directory path and the access level assigned to that endpoint or command/command directory. If the "path" attribute refers to a command/command directory path, the tuple could additionally contain an optional query. The REST endpoint can be a resource-qualified endpoint. At present, the only supported resource-qualified endpoints are /api/storage/volumes/{volume.uuid}/snapshots and /api/storage/volumes//snapshots. "" is a wildcard character denoting "all" volumes.
_links |
access |
string |
Access level for the REST endpoint or command/command directory path. If it denotes the access level for a command/command directory path, the only supported enum values are 'none','readonly' and 'all'. |
path |
string |
Either of REST URI/endpoint OR command/command directory path. |
query |
string |
Optional attribute that can be specified only if the "path" attribute refers to a command/command directory path. The privilege tuple implicitly defines a set of objects the role can or cannot access at the specified access level. The query further reduces this set of objects to a subset of objects that the role is allowed to access. The query attribute must be applicable to the command/command directory specified by the "path" attribute. It is defined using one or more parameters of the command/command directory path specified by the "path" attribute. |
role
A named set of privileges that defines the rights an account has when it is assigned the role.
_links |
builtin |
boolean |
Indicates if this is a built-in (pre-defined) role which cannot be modified or deleted. |
comment |
string |
Comment |
name |
string |
Role name |
owner |
Owner name and UUID that uniquely identifies the role. |
privileges |
array[role_privilege] |
The list of privileges that this role has been granted. |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
