REST API reference
Retrieve a list of roles configured in the cluster
Retrieves a list of roles configured in the cluster, helping you understand the available access permissions.
HTTP method and endpoint
GET /security/roles
Introduced in
ONTAP 9.6
  • security login rest-role show
  • security login role show
Learn more
owner.uuid
string
query
False
Filter by owner.uuid
  • Introduced in: 9.7
owner.name
string
query
False
Filter by owner.name
name
string
query
False
Filter by name
privileges.query
string
query
False
Filter by privileges.query
  • Introduced in: 9.11
privileges.access
string
query
False
Filter by privileges.access
privileges.path
string
query
False
Filter by privileges.path
builtin
boolean
query
False
Filter by builtin
scope
string
query
False
Filter by scope
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[role]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "name": "admin",
      "owner": {
        "name": "svm1",
      "privileges": [
          "access": "all",
          "path": "volume move start",
          "query": "-vserver vs1|vs2|vs3 -destination-aggregate aggr1|aggr2"
      "scope": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
owner
Owner name and UUID that uniquely identifies the role.
_links
_links
name
string
uuid
string
role_privilege
A tuple containing a REST endpoint or a command/command directory path and the access level assigned to that endpoint or command/command directory. If the "path" attribute refers to a command/command directory path, the tuple could additionally contain an optional query. The REST endpoint can be a resource-qualified endpoint. At present, the only supported resource-qualified endpoints are the following
Snapshots APIs
  • /api/storage/volumes/{volume.uuid}/snapshots
File System Analytics APIs
  • /api/storage/volumes/{volume.uuid}/files
  • /api/storage/volumes/{volume.uuid}/top-metrics/clients
  • /api/storage/volumes/{volume.uuid}/top-metrics/directories
  • /api/storage/volumes/{volume.uuid}/top-metrics/files
  • /api/storage/volumes/{volume.uuid}/top-metrics/users
  • /api/svm/svms/{svm.uuid}/top-metrics/clients
  • /api/svm/svms/{svm.uuid}/top-metrics/directories
  • /api/svm/svms/{svm.uuid}/top-metrics/files
  • /api/svm/svms/{svm.uuid}/top-metrics/users
  • /api/protocols/s3/services/{svm.uuid}/users
In the above APIs, wildcard character * could be used in place of {volume.uuid} or {svm.uuid} to denote all volumes or all SVMs, depending upon whether the REST endpoint references volumes or SVMs. The {volume.uuid} refers to the -instance-uuid field value in the "volume show" command output at diagnostic privilege level. It can also be fetched through REST endpoint /api/storage/volumes.
_links
_links
access
string
Access level for the REST endpoint or command/command directory path. If it denotes the access level for a command/command directory path, the only supported enum values are 'none','readonly' and 'all'.
path
string
Either of REST URI/endpoint OR command/command directory path.
query
string
Optional attribute that can be specified only if the "path" attribute refers to a command/command directory path. The privilege tuple implicitly defines a set of objects the role can or cannot access at the specified access level. The query further reduces this set of objects to a subset of objects that the role is allowed to access. The query attribute must be applicable to the command/command directory specified by the "path" attribute. It is defined using one or more parameters of the command/command directory path specified by the "path" attribute.
role
A named set of privileges that defines the rights an account has when it is assigned the role.
_links
_links
builtin
boolean
Indicates if this is a built-in (pre-defined) role which cannot be modified or deleted.
name
string
Role name
owner
owner
privileges
array[role_privilege]
The list of privileges that this role has been granted.
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
