REST API reference
Retrieve the volume file clone split load
Retrieves information about the split load of a volume file clone, helping you understand the current progress and status of the operation.
HTTP method and endpoint
GET /storage/file/clone/split-loads/{node.uuid}
Introduced in
ONTAP 9.10
Usage notes
Retrieve Volume File Clone Split Load REST
node.uuid
string
path
True
Node Uuid
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
load
load
node
node_reference
      "href": "/api/resourcelink"
  "load": {
    "allowable": 0,
    "current": 0,
    "token_reserved": 0
  "node": {
    "name": "node1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
load
allowable
integer
Specifies the available file clone split load on the node.
current
integer
Specifies the current on-going file clone split load on the node.
maximum
integer
Specifies the maximum allowable file clone split load on the node at any point in time.
token_reserved
integer
Specifies the file clone split load on the node reserved for tokens.
self
node_reference
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
