REST API reference
Retrieve the volume file clone split load
Accesses the volume file clone split load information to understand the current load and manage clone operations effectively.
HTTP method and endpoint
GET /storage/file/clone/split-loads/{node.uuid}
Introduced in
ONTAP 9.10
Usage notes
Retrieve Volume File Clone Split Load REST
node.uuid
string
path
True
Node Uuid
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
load
load
node
node
      "href": "/api/resourcelink"
  "load": {
    "allowable": 0,
    "current": 0,
    "maximum": 4096,
    "token_reserved": 0
  "node": {
    "name": "node1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
load
allowable
integer
Specifies the available file clone split load on the node.
current
integer
Specifies the current on-going file clone split load on the node.
maximum
integer
Specifies the maximum allowable file clone split load on the node at any point in time.
token_reserved
integer
Specifies the file clone split load on the node reserved for tokens.
self
node
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
