Retrieve the volume file clone split load
Accesses the details of a volume file clone split load to understand its current state and performance metrics within your ONTAP environment. Use this information to monitor and optimize your storage operations effectively.
HTTP method and endpoint
GET /storage/file/clone/split-loads/{node.uuid}
Introduced in
ONTAP 9.10
Usage notes
Retrieve Volume File Clone Split Load REST
node.uuid |
string |
path |
True |
Node Uuid |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
load |
node |
"href": "/api/resourcelink"
"load": {
"allowable": 0,
"current": 0,
"token_reserved": 0
"node": {
"name": "node1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
load
allowable |
integer |
Specifies the available file clone split load on the node. |
current |
integer |
Specifies the current on-going file clone split load on the node. |
maximum |
integer |
Specifies the maximum allowable file clone split load on the node at any point in time. |
token_reserved |
integer |
Specifies the file clone split load on the node reserved for tokens. |
_links
self |
node_reference
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
