REST API reference
Retrieve file clone split status of all volumes
Retrieves the status of file clone splits across all volumes on the node. This information helps you monitor and manage ongoing split processes, including pending clone splits and unsplit sizes.
HTTP method and endpoint
GET /storage/file/clone/split-status/{volume.uuid}
Introduced in
ONTAP 9.10
Usage notes
Retrieves file clone split status of all volumes in the node.
  • volume file clone split status
Learn More
  • [DOC /storage/file/clone]
Retrieves the information of split status.
The GET operation retrieves information about split processes in the volume.<br> pending-clone-splits is the number of files for which file clone split is not yet completed.<br> unsplit-size is the sum of all sizes, in bytes in the volume that is not split.<br>
# The API:
/api/storage/file/clone/split-status/{volume.uuid}
# The call:
curl -X GET "https://<mgmt_ip>/api/storage/file/clone/split-status/ac559964-57a3-40cf-b5cb-f3cb99151a7d" -H "accept: application/hal+json"
# The response:
"volume": {
  "uuid": "ac559964-57a3-40cf-b5cb-f3cb99151a7d",
  "name": "vol1",
      "href": "/api/storage/volumes/ac559964-57a3-40cf-b5cb-f3cb99151a7d"
"svm": {
  "name": "vs1"
"pending_splits": 0,
"unsplit_clone_size": 0,
    "href": "/api/storage/file/clone/split-status/ac559964-57a3-40cf-b5cb-f3cb99151a7d"
volume.uuid
string
path
True
Volume Instance UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
pending_splits
integer
Specifies the number of pending file clone split operations in the volume.
svm
svm
unsplit_clone_size
integer
Specifies the space occupied by unsplit file clones in the volume.
volume
volume
      "href": "/api/resourcelink"
  "svm": {
    "name": "svm1",
  "volume": {
    "name": "volume1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
volume
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
