REST API reference
Retrieve file clone split status of all volumes
GET /storage/file/clone/split-status/{volume.uuid}
Introduced In: 9.10
Retrieves file clone split status of all volumes in the node.
  • volume file clone split status
Learn More
  • [DOC /storage/file/clone]
Retrieves the information of split status.
The GET operation retrieves information about split processes in the volume. pending-clone-splits is the number of files for which file clone split is not yet completed. unsplit-size is the sum of all sizes in the volume that is not split, in bytes.
# The API:
/api/storage/file/clone/split-status/{volume.uuid}
# The call:
curl -X GET "https://<mgmt_ip>/api/storage/file/clone/split-status/ac559964-57a3-40cf-b5cb-f3cb99151a7d" -H "accept: application/hal+json"
# The response:
"volume": {
  "uuid": "ac559964-57a3-40cf-b5cb-f3cb99151a7d",
  "name": "vol1",
      "href": "/api/storage/volumes/ac559964-57a3-40cf-b5cb-f3cb99151a7d"
"svm": {
  "name": "vs1"
"pending_splits": 0,
"unsplit_size": 0,
    "href": "/api/storage/file/clone/split-status/ac559964-57a3-40cf-b5cb-f3cb99151a7d"
volume.uuid
string
path
True
Volume Instance UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
pending_splits
integer
Specifies the number of pending file clone split operations in the volume.
svm
svm
unsplit_size
integer
Specifies the space occupied by unsplit file clones in the volume.
volume
volume
      "href": "/api/resourcelink"
  "svm": {
    "name": "svm1",
  "unsplit_size": 0,
  "volume": {
    "name": "volume1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
self
svm
_links
_links
name
string
uuid
string
volume
_links
_links
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
