Retrieve the file clone split status of all volumes
Retrieves the file clone split status of all volumes to monitor ongoing split processes within the node. This helps you understand the progress and size of unsplit clone files in your storage environment.
HTTP method and endpoint
GET /storage/file/clone/split-status/{volume.uuid}
Introduced in
ONTAP 9.10
Usage notes
Retrieves file clone split status of all volumes in the node.
Related Ontap commands
volume file clone split status
Learn More
DOC /storage/file/clone]
Retrieves the information of split status.
The GET operation retrieves information about split processes in the volume.<br>
pending-clone-splits is the number of files for which file clone split is not yet completed.<br>
unsplit-size is the sum of all sizes, in bytes in the volume that is not split.<br>
# The API:
/api/storage/file/clone/split-status/{volume.uuid}
# The call:
curl -X GET "https://<mgmt_ip>/api/storage/file/clone/split-status/ac559964-57a3-40cf-b5cb-f3cb99151a7d" -H "accept: application/hal+json"
# The response:
"volume": {
"uuid": "ac559964-57a3-40cf-b5cb-f3cb99151a7d",
"name": "vol1",
"href": "/api/storage/volumes/ac559964-57a3-40cf-b5cb-f3cb99151a7d"
"svm": {
"name": "vs1"
"pending_splits": 0,
"unsplit_clone_size": 0,
"href": "/api/storage/file/clone/split-status/ac559964-57a3-40cf-b5cb-f3cb99151a7d"
volume.uuid |
string |
path |
True |
Volume Instance UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
pending_splits |
integer |
Specifies the number of pending file clone split operations in the volume. |
svm |
unsplit_clone_size |
integer |
Specifies the space occupied by unsplit file clones in the volume. |
volume |
"href": "/api/resourcelink"
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
