REST API reference
Retrieve a file clone token
Retrieves a file clone token to access details about the token's configuration and status. This can be useful for monitoring or managing file cloning operations.
HTTP method and endpoint
GET /storage/file/clone/tokens/{node.uuid}/{uuid}
Introduced in
ONTAP 9.10
Usage notes
  • volume file clone token show
Retrieve information for single token.
# The call:
curl -X GET "https://<mgmt_ip>/api/storage/file/clone/tokens/97255711-a1ad-11eb-92b2-0050568eb2ca/905c42ce-a74b-11eb-bd86-0050568ec7ae"
# The response:
"node": {
  "uuid": "97255711-a1ad-11eb-92b2-0050568eb2ca",
  "name": "node1",
      "href": "/api/cluster/nodes/97255711-a1ad-11eb-92b2-0050568eb2ca"
"uuid": "905c42ce-a74b-11eb-bd86-0050568ec7ae",
"reserve_size": 41943040,
"expiry_time": {
  "limit": "PT1H10M",
  "left": "PT1H9M"
    "href": "/api/storage/file/clone/tokens/97255711-a1ad-11eb-92b2-0050568eb2ca/905c42ce-a74b-11eb-bd86-0050568ec7ae"
Learn More
  • [DOC /storage/file/clone]
node.uuid
string
path
True
Node UUID
uuid
string
path
True
Token UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
expiry_time
expiry_time
node
node_reference
reserve_size
integer
Specifies the available reserve in the file clone split load for the given token.
uuid
string
Token UUID.
      "href": "/api/resourcelink"
  "expiry_time": {
    "left": "string",
    "limit": "string"
  "node": {
    "name": "node1",
  "reserve_size": 0,
  "uuid": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
expiry_time
left
string
Specifies the time remaining before the given token expires in ISO-8601 format.
limit
string
Specifies when the given token expires in ISO-8601 format.
self
node_reference
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
