Retrieve a file clone token
GET /storage/file/clone/tokens/{node.uuid}/{uuid}
Introduced In: 9.10
Retrieves a file clone token
Related Ontap command
volume file clone token show
Retrieve information for single token.
# The call:
curl -X GET "https://<mgmt_ip>/api/storage/file/clone/tokens/97255711-a1ad-11eb-92b2-0050568eb2ca/905c42ce-a74b-11eb-bd86-0050568ec7ae"
# The response:
"node": {
  "uuid": "97255711-a1ad-11eb-92b2-0050568eb2ca",
  "name": "node1",
      "href": "/api/cluster/nodes/97255711-a1ad-11eb-92b2-0050568eb2ca"
"uuid": "905c42ce-a74b-11eb-bd86-0050568ec7ae",
"reserve_size": 41943040,
"expiry_time": {
  "limit": "PT1H10M",
    "href": "/api/storage/file/clone/tokens/97255711-a1ad-11eb-92b2-0050568eb2ca/905c42ce-a74b-11eb-bd86-0050568ec7ae"
Learn More
DOC /storage/file/clone]
node.uuid  |
string  |
path  |
True  |
Node UUID  |
uuid  |
string  |
path  |
True  |
Token UUID  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
expiry_time  |
node  |
reserve_size  |
integer  |
Specifies the available reserve in the file clone split load for the given token. Also note that the minimum value for reserve size is 4KB and any value specified below 4KB will be rounded off to 4KB.  |
uuid  |
string  |
Token UUID.  |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
13565958  |
Failed to get information about token   |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
self_link
self  |
expiry_time
left  |
string  |
Specifies the time remaining before the given token expires in ISO-8601 format.  |
limit  |
string  |
Specifies when the given token expires in ISO-8601 format.  |
node
name  |
string  |
Node name  |
uuid  |
string  |
Node UUID  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
