Retrieve a file clone token
Retrieves a file clone token to access the details and status of a specific file clone operation. This is useful for monitoring the progress or outcome of cloning operations within your storage environment.
HTTP method and endpoint
GET /storage/file/clone/tokens/{node.uuid}/{uuid}
Introduced in
ONTAP 9.10
Usage notes
Related Ontap command
volume file clone token show
Retrieve information for single token.
# The call:
curl -X GET "https://<mgmt_ip>/api/storage/file/clone/tokens/97255711-a1ad-11eb-92b2-0050568eb2ca/905c42ce-a74b-11eb-bd86-0050568ec7ae"
# The response:
"node": {
"uuid": "97255711-a1ad-11eb-92b2-0050568eb2ca",
"name": "node1",
"href": "/api/cluster/nodes/97255711-a1ad-11eb-92b2-0050568eb2ca"
"uuid": "905c42ce-a74b-11eb-bd86-0050568ec7ae",
"reserve_size": 41943040,
"expiry_time": {
"limit": "PT1H10M",
"left": "PT1H9M"
"href": "/api/storage/file/clone/tokens/97255711-a1ad-11eb-92b2-0050568eb2ca/905c42ce-a74b-11eb-bd86-0050568ec7ae"
Learn More
DOC /storage/file/clone]
node.uuid |
string |
path |
True |
Node UUID |
uuid |
string |
path |
True |
Token UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
expiry_time |
node |
reserve_size |
integer |
Specifies the available reserve in the file clone split load for the given token. |
uuid |
string |
Token UUID. |
"href": "/api/resourcelink"
"expiry_time": {
"left": "string",
"limit": "string"
"node": {
"name": "node1",
"reserve_size": 0,
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
expiry_time
left |
string |
Specifies the time remaining before the given token expires in ISO-8601 format. |
limit |
string |
Specifies when the given token expires in ISO-8601 format. |
_links
self |
node_reference
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
