Retrieve users with the most I/O activity
Retrieves a list of users with the most I/O activity to assess performance and resource utilization.
HTTP method and endpoint
GET /storage/volumes/{volume.uuid}/top-metrics/users
Introduced in
ONTAP 9.10
Usage notes
Retrieves a list of users with the most IO activity.
volume.uuid |
string |
path |
True |
Volume UUID |
top_metric |
string |
query |
False |
IO activity type
notice.message |
string |
query |
False |
Filter by notice.message |
notice.code |
string |
query |
False |
Filter by notice.code |
volume.name |
string |
query |
False |
Filter by volume.name |
iops.error.lower_bound |
integer |
query |
False |
Filter by iops.error.lower_bound |
iops.error.upper_bound |
integer |
query |
False |
Filter by iops.error.upper_bound |
iops.write |
integer |
query |
False |
Filter by iops.write |
iops.read |
integer |
query |
False |
Filter by iops.read |
user_name |
string |
query |
False |
Filter by user_name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
user_id |
string |
query |
False |
Filter by user_id |
throughput.write |
integer |
query |
False |
Filter by throughput.write |
throughput.error.lower_bound |
integer |
query |
False |
Filter by throughput.error.lower_bound |
throughput.error.upper_bound |
integer |
query |
False |
Filter by throughput.error.upper_bound |
throughput.read |
integer |
query |
False |
Filter by throughput.read |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
notice |
Optional field that indicates why no records are returned by the volume activity tracking REST API. |
num_records |
integer |
Number of records. |
records |
array[top_metrics_user] |
"next": {
"href": "/api/resourcelink"
"notice": {
"code": "111411207",
"message": "No read/write traffic on volume."
"records": [
"iops": {
"error": {
"lower_bound": 34,
"upper_bound": 54
"read": 4,
"write": 8
"notice": {
"svm": {
"name": "svm1",
"throughput": {
"error": {
"lower_bound": 34,
"upper_bound": 54
"read": 10,
"write": 7
"user_id": "S-1-5-21-256008430-3394229847-3930036330-1001",
"user_name": "James",
"volume": {
"name": "volume1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
notice
code |
string |
Warning code indicating why no records are returned. |
message |
string |
Details why no records are returned. |
top_metric_value_error_bounds
lower_bound |
integer |
Lower bound of the nominal value of a metric. |
upper_bound |
integer |
Upper bound of the nominal value of a metric. |
iops
error |
read |
integer |
Average number of read operations per second. |
write |
integer |
Average number of write operations per second. |
_links
self |
notice
_links |
code |
string |
message |
string |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
throughput
error |
read |
integer |
Average number of read bytes received per second. |
write |
integer |
Average number of write bytes received per second. |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
top_metrics_user
Information about a user's IO activity.
iops |
notice |
svm |
throughput |
user_id |
string |
User ID of the user. |
user_name |
string |
Name of the user. |
volume |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
